I found something ‘weird’ that I could not explain and, maybe, somebody could help me understanding the reason behind.
I’m using lammps as a library for a very simple python code that runs twice the same simulation (intestine.in)
from lammps import lammps
import numpy as np
from mpi4py import MPI
comm = MPI.COMM_WORLD
me = comm.Get_rank()
lmp = lammps()
lmp.file(“intestine.in”)
lmp.close()
lmp = lammps()
lmp.close()
If I run it in serial (no mpi4py etc.) it works perfectly and it runs both simulations.
If I run the parallel version, the first simulation runs correctly, but it crashes when it tries to run the second one (which is exactly the same of the first)
ERROR on proc 1: Divide by 0 in variable formula (src/variable.cpp:2876)
Last command: run ${Nsteps}
What it is even more puzzling to me is that this happens only if the initial geometry is read from a text data file , while if (the same geometry) is read from a restart binary file, both simulation ran as supposed.
If there were something wrong in any of my files or in how the lammps library was compiled, it wouldn’t run the first time. If there were something wrong in my python script, it wouldn’t work fine with the binary data file. I really do not understand.
Does anybody a clue of why this happens? The input files is attached, but the data file are too large.
On a non-related subject. I use the Digest version of the mailing list, but I am not sure how I can answer somebody’s post from there (other than copy and paste their email address and send a private message)
Best
Alessio
Dr. Alessio Alexiadis
intestine.in (3.63 KB)
