I get the following messages when I try to build LAMMPS.
pppm_cuda.cpp(941): error: class “LAMMPS_NS::FFT3dCuda” has no member “set_cudata”
fft1c->set_cudata(cu_work2->dev_data(),cu_work1->dev_data());
pppm_cuda.cpp(942): error: class “LAMMPS_NS::FFT3dCuda” has no member “set_cudata”
fft2c->set_cudata(cu_work2->dev_data(),cu_work3->dev_data());
compilation aborted for pppm_cuda.cpp (code 2)
Please let me know how to fix the problem. I’m using the most recent revision from the repository.
- Mo Zhang
