Hi, I want to use the GPU accelerator package, but there is an error:
ERROR on proc 1: Neighbor list problem on the GPU. Try increasing the value of 'neigh_modify one' or the GPU neighbor list 'binsize'. (../fix_gpu.cpp:340)
Here is my input file:
units lj
atom_style full
special_bonds fene
package gpu 1 neigh yes
read_data lammps.data extra/bond/per/atom 10 extra/special/per/atom 100
group colloid type 1
group polymer type 2 3 4
group reaction type 1 2
#kspace_style pppm 1e-6
pair_style lj/expand 0.448 #lj/expand/coul/long 0.448 5.0
pair_modify shift yes
pair_coeff 1 1 0.0 0.2 0.0 0.224
pair_coeff 1 2 1.0 0.4 -0.1 2.5
pair_coeff 1 3 0.1 0.4 -0.1 0.448
pair_coeff 1 4 0.1 0.4 -0.1 0.448
pair_coeff 2 2 0.1 0.2 0.0 0.224
pair_coeff 2 3 0.1 0.2 0.0 0.224
pair_coeff 2 4 0.1 0.2 0.0 0.224
pair_coeff 3 3 0.1 0.2 0.0 0.224
pair_coeff 3 4 0.1 0.2 0.0 0.224
pair_coeff 4 4 0.1 0.2 0.0 0.224
bond_style fene/expand
bond_coeff 1 300.0 1.0 0.1 0.2 0.0
bond_coeff 2 300.0 1.0 0.1 0.4 -0.1
neighbor 1.0 bin
thermo 1000
thermo_style custom step temp ke pe etotal
#dump output all custom 1000 output.lammpstrj id type x y z ix iy iz
#dump_modify output sort id
#fix step1 colloid rigid/nve single langevin 1.0 1.0 0.1 85723610
fix fix_colloid colloid setforce 0 0 0
fix step2 polymer nve
fix step3 polymer langevin 1.0 1.0 1.0 93627450
fix reaction_step reaction bond/create 5000 1 2 0.348 2 iparam 1 1 jparam 1 2 prob 0.5 85784221
timestep 0.001
run 1000000
write_data final.data nocoeff
#unfix step1
unfix fix_colloid
unfix step2
unfix step3
unfix reaction_step
clear
and I use the command: mpirun -np 2 lmp_mpi -sf gpu -in in.lammps
Here is my GPU information:
Found 1 platform(s).
CUDA Driver Version: 12.80
Device 0: "NVIDIA GeForce RTX 5080"
Type of device: GPU
Compute capability: 12
Double precision support: Yes
Total amount of global memory: 15.4791 GB
Number of compute units/multiprocessors: 84
Number of cores: 16128
Total amount of constant memory: 65536 bytes
Total amount of local/shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per block: 1024
Maximum group size (# of threads per block) 1024 x 1024 x 64
Maximum item sizes (# threads for each dim) 2147483647 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Clock rate: 2.655 GHz
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default
Concurrent kernel execution: Yes
Device has ECC support enabled: No
Besides, I tested the lammps example/shear: mpirun -np 2 lmp_mpi -sf gpu -in in.shear, it can run successfully:
LAMMPS (29 Aug 2024 - Update 1)
Lattice spacing in x,y,z = 3.52 3.52 3.52
Created orthogonal box = (0 0 0) to (56.32 35.2 9.956063)
2 by 1 by 1 MPI processor grid
Lattice spacing in x,y,z = 3.52 4.9780317 4.9780317
Created 1912 atoms
using lattice units in orthogonal box = (-0.005632 -0.00352 0) to (56.325632 35.20352 9.956063)
create_atoms CPU = 0.000 seconds
Reading eam potential file Ni_u3.eam with DATE: 2007-06-11
264 atoms in group lower
264 atoms in group upper
528 atoms in group boundary
1384 atoms in group mobile
Setting atom values ...
264 settings made for type
WARNING: Temperature for thermo pressure is not for group all (../thermo.cpp:533)
CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE
Your simulation uses code contributions which should be cited:
- GPU package (short-range, long-range and three-body potentials): doi:10.1016/j.cpc.2010.12.021, doi:10.1016/j.cpc.2011.10.012, doi:10.1016/j.cpc.2013.08.002, doi:10.1016/j.commatsci.2014.10.068, doi:10.1016/j.cpc.2016.10.020, doi:10.3233/APC200086
The log file lists these citations in BibTeX format.
- Using acceleration for eam:
- with 1 proc(s) per device.
- Horizontal vector operations: ENABLED
- Shared memory system: No
Device 0: NVIDIA GeForce RTX 5080, 84 CUs, 15/15 GB, 2.7 GHZ (Mixed Precision)
Device 1: NVIDIA GeForce RTX 5080, 84 CUs, 2.7 GHZ (Mixed Precision)
Initializing Device and compiling on process 0...Done.
Initializing Devices 0-1 on core 0...Done.
Setting up Verlet run ...
Unit style : metal
Current step : 0
Time step : 0.001
Per MPI rank memory allocation (min/avg/max) = 2.574 | 2.574 | 2.575 Mbytes
Step Temp E_pair E_mol TotEng Press Volume
0 300 -8317.4367 0 -8263.8066 -7100.6278 19547.02
25 218.96729 -8271.6701 0 -8232.526 5018.9555 19547.02
50 300 -8238.2244 0 -8184.5944 12937.814 19693.626
75 295.22062 -8232.3247 0 -8179.549 13096.236 19751.41
100 300 -8248.5066 0 -8194.8765 7631.67 19813.143
Loop time of 0.594331 on 2 procs for 100 steps with 1912 atoms
Performance: 14.537 ns/day, 1.651 hours/ns, 168.256 timesteps/s, 321.706 katom-step/s
100.0% CPU use with 2 MPI tasks x no OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0.30009 | 0.44656 | 0.59303 | 21.9 | 75.14
Neigh | 4.187e-06 | 4.929e-06 | 5.671e-06 | 0.0 | 0.00
Comm | 0.00071203 | 0.026911 | 0.053111 | 16.0 | 4.53
Output | 4.5775e-05 | 0.0021482 | 0.0042506 | 4.5 | 0.36
Modify | 0.00031167 | 0.014323 | 0.028334 | 11.7 | 2.41
Other | | 0.1044 | | | 17.56
Nlocal: 956 ave 976 max 936 min
Histogram: 1 0 0 0 0 0 0 0 0 1
Nghost: 1364 ave 1379 max 1349 min
Neighs: 0 ave 0 max 0 min
Histogram: 2 0 0 0 0 0 0 0 0 0
Total # of neighbors = 0
Ave neighs/atom = 0
Neighbor list builds = 4
Dangerous builds = 0
Device Time Info (average):
Data Transfer: 0.0071 s.
Neighbor copy: 0.0010 s.
Neighbor build: 0.0062 s.
Force calc: 0.2824 s.
Device Overhead: 0.1267 s.
CPU Neighbor: 0.0001 s.
CPU Cast/Pack: 0.0004 s.
CPU Driver_Time: 0.0016 s.
CPU Idle_Time: 0.1488 s.
Average split: 1.0000.
Max Mem / Proc: 0.70 MB.
Prefetch mode: None.
Vector width: 32.
Lanes / atom: 4.
Pair block: 256.
Neigh block: 128.
Neigh mode: Hybrid (binning on host) with subgroup support
Unit style : metal
Current step : 0
Time step : 0.001
0 301.61467 -8248.5066 0 -8212.5608 6671.213 19834.251
100 305.24299 -8258.5336 0 -8222.1554 671.24999 19820.953
200 294.91959 -8256.7221 0 -8221.5742 -100.78904 19951.889
300 308.14232 -8252.9564 0 -8216.2327 -1188.1455 20066.072
400 299.14864 -8246.529 0 -8210.8771 -566.39181 20098.934
500 291.26312 -8238.3115 0 -8203.5994 1088.1969 20167.288
600 290.23348 -8230.4777 0 -8195.8883 3509.3183 20273.78
700 300 -8221.1504 0 -8185.3971 5951.52 20398.367
800 294.03107 -8206.273 0 -8171.231 11114.423 20508.297
900 294.38115 -8195.0448 0 -8159.9611 13565.239 20635.327
1000 300.21982 -8183.5656 0 -8147.786 16578.22 20766.022
1100 306.88214 -8167.459 0 -8130.8854 20551.628 20877.174
1200 297.88108 -8156.1944 0 -8120.6936 22500.643 21007.868
1300 300 -8149.5453 0 -8113.792 20848.779 21121.462
1400 300 -8141.6935 0 -8105.9401 20037.619 21249.714
1500 300 -8134.2882 0 -8098.5348 18731.246 21374.301
1600 300 -8133.3805 0 -8097.6272 15445.526 21494.003
1700 300 -8146.3578 0 -8110.6044 9680.3758 21613.705
1800 307.69417 -8151.5348 0 -8114.8645 9399.931 21732.185
1900 300 -8159.8865 0 -8124.1331 8478.6512 21861.658
2000 300 -8160.1243 0 -8124.371 7536.8943 21980.138
2100 307.27369 -8163.9448 0 -8127.3246 3854.3162 22107.168
2200 307.26749 -8163.2971 0 -8126.6776 2361.9376 22224.427
2300 300 -8168.2346 0 -8132.4813 1945.4271 22347.793
2400 300 -8179.5165 0 -8143.7631 -1979.8264 22468.716
2500 302.78588 -8179.0012 0 -8142.9158 -4748.8636 22594.524
2600 304.81386 -8174.8013 0 -8138.4742 -4885.6959 22709.34
2700 300.78581 -8176.429 0 -8140.582 -6164.9424 22840.035
2800 300 -8174.6046 0 -8138.8513 -7735.8932 22967.065
2900 300 -8171.2686 0 -8135.5153 -9678.5758 23080.659
3000 295.35661 -8168.4433 0 -8133.2433 -9148.2385 23204.025
Loop time of 18.0334 on 2 procs for 3000 steps with 1912 atoms
Performance: 14.373 ns/day, 1.670 hours/ns, 166.358 timesteps/s, 318.076 katom-step/s
Pair | 9.357 | 13.68 | 18.004 | 116.9 | 75.86
Neigh | 0.00014138 | 0.00014883 | 0.00015627 | 0.0 | 0.00
Comm | 0.016654 | 1.1698 | 2.3229 | 106.6 | 6.49
Output | 0.00031152 | 0.00037786 | 0.00044421 | 0.0 | 0.00
Modify | 0.0079357 | 0.43592 | 0.86391 | 64.8 | 2.42
Other | | 2.747 | | | 15.23
Nlocal: 956 ave 962 max 950 min
Nghost: 1373.5 ave 1375 max 1372 min
Ave neighs/atom = 0
Neighbor list builds = 226
Data Transfer: 0.2189 s.
Neighbor copy: 0.0043 s.
Neighbor build: 0.2977 s.
Force calc: 8.4098 s.
Device Overhead: 2.6529 s.
CPU Neighbor: 0.0040 s.
CPU Cast/Pack: 0.0106 s.
CPU Driver_Time: 0.0340 s.
CPU Idle_Time: 4.3663 s.
Max Mem / Proc: 0.62 MB.
Vector width: 32.
Lanes / atom: 4.
Pair block: 256.
Neigh block: 128.
Total wall time: 0:00:19
How can I solve this error?
