Dear community,
I am trying to compile lammps on the linux cluster
and i end up with the following error.
Based on
- Voronoi
- Kim package.
I removed the two packages from the list
and precede the compilation.
But, lately i end up with an error in the linking libraries.
a.o run.o set.o special.o tad.o temper.o thermo.o timer.o universe.o update.o variable.o velocity.o verlet.o verlet_split.o write_restart.o xdr_compat.o -lreax -lpoems -lmeam -lfftw -lifcore -lsvml -lompstub -limf -lgfortran -lstdc++ -o …/lmp_openmpi
/usr/bin/ld: cannot find -lifcore
collect2: ld returned 1 exit status
make[1]: *** […/lmp_openmpi] Error 1
make[1]: Leaving directory `/src/Obj_openmpi’
Can any one help me with this.
the error associated with the KIM and Volonoi packages
are given below.
best regards
Vimal
-I/KIM_API -c create_box.cpp
compute_voronoi_atom.cpp:34: error: ‘voro’ is not a namespace-name
compute_voronoi_atom.cpp:34: error: expected namespace-name before ‘;’ token
compute_voronoi_atom.cpp: In member function ‘virtual void LAMMPS_NS::ComputeVoronoi::compute_peratom()’:
compute_voronoi_atom.cpp:106: error: ‘container’ was not declared in this scope
compute_voronoi_atom.cpp:106: error: expected ‘;’ before ‘con’
compute_voronoi_atom.cpp:115: error: ‘con’ was not declared in this scope
compute_voronoi_atom.cpp:122: error: ‘voronoicell_neighbor’ was not declared in this scope
compute_voronoi_atom.cpp:122: error: expected ‘;’ before ‘c’
compute_voronoi_atom.cpp:123: error: ‘c_loop_all’ was not declared in this scope
compute_voronoi_atom.cpp:123: error: expected ‘;’ before ‘cl’
compute_voronoi_atom.cpp:124: error: ‘cl’ was not declared in this scope
compute_voronoi_atom.cpp:124: error: ‘con’ was not declared in this scope
compute_voronoi_atom.cpp:124: error: ‘c’ was not declared in this scope
make[1]: *** [compute_voronoi_atom.o] Error 1
make[1]: *** Waiting for unfinished jobs…
make[1]: Leaving directory `/scratch/agvalenti/muthukumar/Lammps/New_1/lammps-9Mar13/src/Obj_linux’
make: *** [linux] Error 2
.cpp
pair_kim.cpp:41:21: error: KIM_API.h: No such file or directory
pair_kim.cpp:42:28: error: KIM_API_status.h: No such file or directory
pair_kim.cpp: In member function ‘virtual void LAMMPS_NS::PairKIM::compute(int, int)’:
pair_kim.cpp:173: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.h:35: error: forward declaration of ‘struct KIM_API_model’
pair_kim.cpp:183: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp: In member function ‘virtual void LAMMPS_NS::PairKIM::init_style()’:
pair_kim.cpp:395: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:396: error: ‘KIM_STATUS_OK’ was not declared in this scope
pair_kim.cpp: In member function ‘void LAMMPS_NS::PairKIM::kim_error(int, const char*, int)’:
pair_kim.cpp:586: error: ‘KIM_STATUS_OK’ was not declared in this scope
pair_kim.cpp:587: error: incomplete type ‘KIM_API_model’ used in nested name specifier
pair_kim.cpp: In static member function ‘static int LAMMPS_NS::PairKIM::get_neigh(void**, int*, int*, int*, int*, int**, double**)’:
pair_kim.cpp:601: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:647: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:661: error: ‘KIM_STATUS_OK’ was not declared in this scope
pair_kim.cpp:664: error: ‘KIM_STATUS_NEIGH_ITER_PAST_END’ was not declared in this scope
pair_kim.cpp:671: error: ‘KIM_STATUS_NEIGH_ITER_INIT_OK’ was not declared in this scope
pair_kim.cpp:695: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:704: error: ‘KIM_STATUS_OK’ was not declared in this scope
pair_kim.cpp:707: error: ‘KIM_STATUS_NEIGH_INVALID_REQUEST’ was not declared in this scope
pair_kim.cpp:711: error: ‘KIM_STATUS_OK’ was not declared in this scope
pair_kim.cpp:713: error: ‘KIM_STATUS_NEIGH_INVALID_MODE’ was not declared in this scope
pair_kim.cpp: In member function ‘void LAMMPS_NS::PairKIM::kim_free()’:
pair_kim.cpp:726: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:731: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:736: warning: possible problem detected in invocation of delete operator:
pair_kim.cpp:736: warning: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.h:35: warning: forward declaration of ‘struct KIM_API_model’
pair_kim.cpp:736: note: neither the destructor nor the class-specific operator delete will be called, even if they are declared when the class is defined.
pair_kim.cpp: In member function ‘void LAMMPS_NS::PairKIM::kim_init()’:
pair_kim.cpp:764: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:765: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:766: error: ‘KIM_STATUS_OK’ was not declared in this scope
pair_kim.cpp:778: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:780: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:789: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:810: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp: In member function ‘void LAMMPS_NS::PairKIM::set_statics()’:
pair_kim.cpp:828: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:838: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp: In member function ‘void LAMMPS_NS::PairKIM::set_volatiles()’:
pair_kim.cpp:852: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:859: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:865: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:872: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:874: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:886: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:886: error: ‘KIM_COMPUTE_FALSE’ was not declared in this scope
pair_kim.cpp:888: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:888: error: ‘KIM_COMPUTE_TRUE’ was not declared in this scope
pair_kim.cpp:894: error: invalid use of incomplete type ‘struct KIM_API_model’
pair_kim.cpp:895: error: ‘KIM_COMPUTE_FALSE’ was not declared in this scope
pair_kim.cpp:895: error: ‘KIM_COMPUTE_TRUE’ was not declared in this scope
pair_kim.cpp: In member function ‘void LAMMPS_NS::PairKIM::set_kim_model_has_flags()’:
pair_kim.cpp:952: error: aggregate ‘KIM_API_model mdl’ has incomplete type and cannot be defined
pair_kim.cpp:962: error: ‘KIM_STATUS_OK’ was not declared in this scope
make[1]: *** [pair_kim.o] Error 1
