Dear All,
I encountered a problem with Lammps when applying MEAM potential to Si. The Lammps is the latest version for 32-bit Windows.
My detailed situation is that: I wanted to calculate the ISF energy of Si on the glide planes and compare the results by using Tersoff and MEAM potentials. The MEAM library file is library.meam in Lammps’ package and the MEAM parameter file is obtained from Baskes’ paper [Phys. Rev. B 46 (1992) 2727–2742].
The lmp_mpi.exe (as well as lmp_serial.exe) run very well with Tersoff potential, but stoped working with MEAM. The system gave warnings as following:
问题签名:
问题事件名称: APPCRASH
应用程序名: lmp_mpi.exe
应用程序版本: 0.0.0.0
应用程序时间戳: 522f058b
故障模块名称: lmp_mpi.exe
故障模块版本: 0.0.0.0
故障模块时间戳: 522f058b
异常代码: c0000005
异常偏移: 00843945
OS 版本: 6.1.7600.2.0.0.256.1
区域设置 ID: 2052
其他信息 1: 0a9e
其他信息 2: 0a9e372d3b4ad19135b953a78882e789
其他信息 3: 0a9e
其他信息 4: 0a9e372d3b4ad19135b953a78882e789
(Unfortunately, my OS language is not English. True sorry for any inconvenience.)
I also attached the input scripts and MEAM library and parameter files. Does anyone encounter similar problems with me? Since the problem has troubled me for a long time, I would be most grateful if anyone like to help me to test my input scripts and check out what is the problem.
Thanks in advance.
-Wilhelm
in.stack_fault_Si.txt (1.6 KB)
library.meam (10.4 KB)
Si.meam (57 Bytes)
