I had lammps installed properly on my linux system (lammps-2Aug2023). and it was working fine until Today that I installed anaconda. when I run lammps on my system:
it prints out the following lines 64 times: Ignoring PCI device with non-16bit domain.
It looks like it prints the regular lammps’s output on screen 64 times (including this statement "OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (…/comm.cpp:98)
") and the file is not running parallel (it runs very slow). those two lines also show up if I run lammps in series without mpirun.
I tried to reinstall lammps but it is still not working. I use the following lines to install lammps:
tar -xvf hwloc-1.11.13.tar.gz
cd hwloc-1.11.13/
./configure
make
sudo make install
sudo apt-get install libhwloc5
sudo apt-get install openmpi-bin
sudo apt-get install openmpi-common
sudo apt-get install g++
sudo apt-get install kissplice
sudo apt-get install fftw
sudo apt-get install fftw-dev
sudo apt-get install mpi-default-dev
sudo apt-get install mpi-default-bin
cd …/lammps-2Aug2023/src
make clean-all
make purge
make no-all
make yes-manybody
make yes-mc
make yes-meam
make yes-misc
make yes-opt
make yes-replica
make yes-rigid
make yes-snap
make yes-user-diffraction
make yes-user-misc
make yes-user-omp
make ubuntu_simple
sudo mv lmp_ubuntu_simple /usr/local/bin/lmp
cd …/…
sudo cp -r lammps-2Aug2023/ /usr/local
Would you please help me solve this issue?
Sepideh
