Hi Lammps Community ![]()
Im trying to do energy minimization of a ternary alloy and the potential i have been using is hdnnp(high dimensional neural network potential). This is just a small task to check the proper working and get familiar with hdnnp. Later on I will be conducting MD simulations on it.
I am using LAMMPS 64-bit 23Jun2022-MPI version on my windows. I have hdnnp support enabled (I could see that when in type <lmp -h> in command prompt and under pair style hdnnp is there). Also all the required files like input data file and scaling file , weight file are placed in one directory.
Although it worked perfectly fine on one fine day , the next day Iam facing an error . Iam attaching the input script file .
The error goes like this —>
LAMMPS (23 Jun 2022 - Update 4)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
Loaded 1 plugins from C:\Users\salun\AppData\Local\LAMMPS 64-bit 23Jun2022-MPI\plugins
clear
atom_style atomic
box tilt large
read_data “data.nn”
Reading data file …
orthogonal box = (0 0 0) to (12.184254 12.184254 12.184254)
reading atoms …
108 atoms
read_data CPU = 0.006 seconds
mass 1 24.305
mass 2 26.9815385
mass 3 28.0855
variable nnpDir string “E:\Al-Mg-Si-HDNNP\small cluster no vac\hdnnp-data”
pair_style hdnnp 10.6 dir {nnpDir} showew no resetew yes maxew 100000000 cflength 1.8897261258369282 cfenergy 0.03674932247495664 pair_style hdnnp 10.6 dir E:\Al-Mg-Si-HDNNP\small cluster no vac\hdnnp-data showew no resetew yes maxew 100000000 cflength 1.8897261258369282 cfenergy 0.03674932247495664 ERROR: Illegal pair_style command (src/ML-HDNNP/pair_hdnnp.cpp:178) Last command: pair_style hdnnp 10.6 dir {nnpDir} showew no resetew yes maxew 100000000 cflength 1.8897261258369282 cfenergy 0.03674932247495664
