I have tried to run a simulation in Lammps using a ReaxFF in HPR and my own computer. The simulation has few particles, about 160. The commands used to run it are as following:
–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–o–
REAX potential for Nitroamines system
units real
atom_style full
read_data Dimer1.dat
pair_style reax/c NULL
pair_coeff * * forcefield.EL C F H Li N O S
neighbor 2. bin
neigh_modify every 10 delay 0 check no
fix 2 all qeq/reax 1 0.0 10.0 1e-6 reax/c
velocity all create 5.0 4928459 rot yes dist gaussian
dielectric 100
fix 1 all npt temp 5.0 330.0 500.0 iso 1.0 1.0 10000.0
timestep 0.1
thermo_style custom step temp evdwl ecoul pe press vol lx ly lz density
thermo 100
dump 1 all custom 100 md1.lammpstrj id type x y z ix iy iz q
run 10000000
write_data Dimer2.dat
It started working fine and everything seemed normal, but after a few femtoseconds it stopped and the following error message was printed in Both computers (HPC and my own computer):
[c469:257480:0:257480] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x6a73e6b0)
==== backtrace (tid: 257480) ====
0 0x0000000001395176 Validate_Lists() ???:0
1 0x00000000013956bd Init_Forces_noQEq() ???:0
2 0x0000000001395e7c Compute_Forces() ???:0
3 0x000000000138cd01 LAMMPS_NS::PairReaxC::compute() ???:0
4 0x0000000000d1cc5e LAMMPS_NS::Verlet::run() ???:0
5 0x0000000000cdc51e LAMMPS_NS::Run::command() ???:0
6 0x0000000000b9442b LAMMPS_NS::Input::command_creator<LAMMPS_NS::Run>() ???:0
7 0x0000000000b92905 LAMMPS_NS::Input::execute_command() ???:0
8 0x0000000000b92e66 LAMMPS_NS::Input::file() ???:0
9 0x0000000000400e58 main() ???:0
10 0x0000000000022555 __libc_start_main() ???:0
11 0x0000000000400eb8 _start() ???:0
[c469:257480] *** Process received signal ***
[c469:257480] Signal: Segmentation fault (11)
[c469:257480] Signal code: (-6)
[c469:257480] Failing at address: 0x673d0003edc8
[c469:257480] [ 0] /lib64/libpthread.so.0(+0xf630)[0x2b8a4adf7630]
[c469:257480] [ 1] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_Z14Validate_ListsP12_reax_systemP7storagePP10_reax_listiiii+0x1b6)[0x2b8a46b6b176]
[c469:257480] [ 2] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_Z17Init_Forces_noQEqP12_reax_systemP14control_paramsP15simulation_dataP7storagePP10_reax_listP15output_controls+0x3cd)[0x2b8a46b6b6bd]
[c469:257480] [ 3] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_Z14Compute_ForcesP12_reax_systemP14control_paramsP15simulation_dataP7storagePP10_reax_listP15output_controlsP13mpi_datatypes+0x2c)[0x2b8a46b6be7c]
[c469:257480] [ 4] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_ZN9LAMMPS_NS9PairReaxC7computeEii+0x1b1)[0x2b8a46b62d01]
[c469:257480] [ 5] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_ZN9LAMMPS_NS6Verlet3runEi+0x21e)[0x2b8a464f2c5e]
[c469:257480] [ 6] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_ZN9LAMMPS_NS3Run7commandEiPPc+0x32e)[0x2b8a464b251e]
[c469:257480] [ 7] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_ZN9LAMMPS_NS5Input15command_creatorINS_3RunEEEvPNS_6LAMMPSEiPPc+0x2b)[0x2b8a4636a42b]
[c469:257480] [ 8] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_ZN9LAMMPS_NS5Input15execute_commandEv+0x875)[0x2b8a46368905]
[c469:257480] [ 9] /sw/eb/sw/LAMMPS/3Mar2020-foss-2019b-Python-3.7.4-kokkos/lib64/liblammps.so.0(_ZN9LAMMPS_NS5Input4fileEv+0x156)[0x2b8a46368e66]
[c469:257480] [10] lmp(main+0x48)[0x400e58]
[c469:257480] [11] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b8a4bb31555]
[c469:257480] [12] lmp[0x400eb8]
[c469:257480] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 33 with PID 257480 on node c469 exited on signal 11 (Segmentation fault).
Does anyone know how I can solve it?
Anderson
