LAMMPS-GUI Version 3.0 released
Dear current (and future?) LAMMPS-GUI users. I have posted a new release: Release Version 2.0.99 · akohlmey/lammps-gui · GitHub
This is numbered and labeled as a “beta” release mostly because of the many changes that have happened internally. The code base has been made more modular, modernized, supports now Qt version 6.x only and has an alternative implementation of the Charts tool that does not depend on the QtCharts module, which is now deprecated since Qt 6.10.
The main user visible change is the support for an upcoming publication of a collection of tutorials for materials science research as a complement to the mostly soft matter focused tutorials collection that is already supported. The tutorial materials can already be accessed, but to make sense, you need the corresponding draft article. If you are interested in giving feedback on that, please send me an email to my personal email account, giving a brief introduction of yourself and your background.
Beyond that there are many detailed changes to individual dialogs. Highlights are the support for coloring bonds by property based on an upcoming feature in LAMMPS and menu options and command line flags that, for instance, allow LAMMPS-GUI to view images from previous simulations or generated by runs on a cluster in the slideshow viewer and to view column-oriented data in the chart viewer and support for some function fitting and post-processing.
I invite you to download this new version and report any issues, either here, in the issue tracker on GitHub or via email. In my own tests it is now as reliable and usable as previous releases, but then again I know where the skeletons are buried, so I am less likely to try things that cause problems.
Many thanks in advance.
woah, the render is impressive!
Pretty straightforward actually. Even simpler, if you use LAMMPS-GUI to set it up and then just copy the commands into the input (which i borrowed from the BPM package examples).
There is now an update and one more beta test step before the 2.1 release: Release Version 2.0.999 · akohlmey/lammps-gui · GitHub
This has some more improvements and fixes.
And another (hopefully final) beta before the 2.1 release. This is more a cosmetic update. After just copying icons from various icon libraries, I have now created a consolidated library of icons in scalable SVG format with a consistent color scheme and style.
I’ve decided that all the accumulated changes justify a bigger step in the version number. This morning I released LAMMPS-GUI version 3.0.0.
This is now the main supported version and it is strongly recommended to upgrade.
This version will also be included in the upcoming next stable release of LAMMPS.
