Hi All,
I have recently been tinkering with the python LAMMPS module and have been working on a short script that performs short NVT relaxations on a molecular crystal and automatically stops and writes a data file when the pressure has converged to within a certain threshold. See the full script below:
log loophugo.log
units real
atom_style full
timestep 1
bond_style harmonic
angle_style harmonic
dihedral_style hybrid harmonic multi/harmonic
improper_style harmonic
#pair_style buck/coul/long 11.0 11.0
pair_style hybrid/overlay table linear 2550 coul/long 15.0
kspace_style pppm 1.0e-6
#kspace_modify slab 3.0
special_bonds lj/coul 0.0 0.0 1.0
read_data tintest.data
pair_coeff 1 1 table HMX_X6table.txt HH
pair_coeff 1 2 table HMX_X6table.txt HN1
pair_coeff 1 3 table HMX_X6table.txt HN2
pair_coeff 1 4 table HMX_X6table.txt HO
pair_coeff 1 5 table HMX_X6table.txt HC
pair_coeff 2 2 table HMX_X6table.txt N1N1
pair_coeff 2 3 table HMX_X6table.txt N1N2
pair_coeff 2 4 table HMX_X6table.txt N1O
pair_coeff 2 5 table HMX_X6table.txt N1C
pair_coeff 3 3 table HMX_X6table.txt N2N2
pair_coeff 3 4 table HMX_X6table.txt N2O
pair_coeff 3 5 table HMX_X6table.txt N2C
pair_coeff 4 4 table HMX_X6table.txt OO
pair_coeff 4 5 table HMX_X6table.txt OC
pair_coeff 5 5 table HMX_X6table.txt CC
pair_coeff * * coul/long
dihedral_coeff 1 multi/harmonic 8.452 0.000 -5.28998 0.00 -3.16003
dihedral_coeff 2 harmonic -0.08 -1 3
dihedral_coeff 3 multi/harmonic 0.095 -1.485 1.61000 -0.22 0.0
neighbor 2.0 bin
#neigh_modify every 1 delay 5
neigh_modify delay 0 every 1 check yes one 10000 page 100000
python rbreak input 2 SELF v_b return v_switch format pii here """
def rbreak(handle, b):
#import scipy as sp
import math as m
from lammps import lammps
lmp = lammps(ptr=handle)
rank = lmp.extract_setting('world_rank')
if rank == 0:
print('1a')
import os
print('1b')
import lammps
print('1c')
from lammps import formats
print('1d')
try:
log = formats.LogFile("loophugo.log")
except:
print("can't find logfile, this is the CWD: "+str(os.getcwd()))
print(2)
P = log.runs[b-1]["Pxx"]
print("Iteration Number: " + str(b))
#try:
#filt = sp.signal.savgol_filter(P,15,2)
#except:
# print("Need more points for each loop iteration, or smaller SAVGOL window length")
print(4)
#if sum(filt[len(filt)-6:len(filt)-1])/10 < 1:
if sum(P[len(P)-6:len(P)-1])/5 < 10:
return int(1)
else:
print('Avg P: ' + str(sum(P[len(P)-6:len(P)-1])/5))
return int(0)
variable rand equal floor(random(1,1000000,3259))
variable switch python rbreak
thermo 10
thermo_style custom step vol temp press pe ke etotal epair evdwl ecoul elong emol ebond eangle edihed eimp enthalpy density lx ly lz pxx pyy pzz pxy pxz pyz
thermo_modify line one
fix 1 all nvt temp 300.0 300.0 100.0
velocity all create 300.0 ${rand} dist gaussian mom yes rot yes
run 60
write_data ./test.data
label thermo_loop
variable b loop 5000
thermo_modify line one flush yes
# reassign velocities every N steps (frequently)
#dump 1 all custom 100 dump.* id type xs ys zs
if "${switch} == 1" then "jump SELF break"
else "run 60"
next b
jump SELF thermo_loop
label break
variable b delete
write_data ./hugo_relaxed_done.data
run 10 pre no
quit
This code bears a lot of scars from my trying to debug it (such as the run 10 pre no command at the bottom). The issue I am having is that the script seems to be running fine and gives indication that the python function is executing well and all, but LAMMPS hangs indefinitely when trying to write the final ./hugo_relaxed_done.data (see record file at end of post). I am having trouble understanding what the problem is here. I do relaxations like this all the time (sans the fancy python machinery) and haven’t run into this issue before. I am confident that the python function is causing some problem with the write_data command, but the connection between the two seems weak as the python function is only defining some binary variable used to break out of the relaxation loop. Does anyone with more experience with the Python module have any clues about what might be happening here?
This is more of a proof-of-concept code, as there are clearly simpler ways to accomplish the relaxation of a large system that don’t involve such complications, but I am hoping to leverage the python interconnectivity on more complicated calculations in the future, so it would be great to get down to the bottom of this.
Record File:
LAMMPS (23 Jun 2022 - Update 2)
Reading data file ...
orthogonal box = (7.8850446 -1.2069369 0.74172168) to (3002.1842 309.90694 285.45828)
32 by 4 by 2 MPI processor grid
reading atoms ...
2462523 atoms
reading velocities ...
2462523 velocities
scanning bonds ...
3 = max bonds/atom
scanning angles ...
6 = max angles/atom
scanning dihedrals ...
4 = max dihedrals/atom
scanning impropers ...
1 = max impropers/atom
reading bonds ...
2462523 bonds
reading angles ...
4221468 angles
reading dihedrals ...
3517890 dihedrals
reading impropers ...
703578 impropers
special bond factors lj: 0 0 1
special bond factors coul: 0 0 1
4 = max # of 1-2 neighbors
8 = max # of 1-3 neighbors
11 = max # of special neighbors
special bonds CPU = 3.255 seconds
read_data CPU = 55.141 seconds
WARNING: 1 of 2550 force values in table HN1 are inconsistent with -dE/dr.
WARNING: Should only be flagged at inflection points (src/pair_table.cpp:463)
WARNING: 1 of 2550 force values in table HN2 are inconsistent with -dE/dr.
WARNING: 1 of 2550 force values in table HC are inconsistent with -dE/dr.
WARNING: 1 of 2550 force values in table OC are inconsistent with -dE/dr.
WARNING: 1 of 2550 force values in table CC are inconsistent with -dE/dr.
PPPM initialization ...
using 12-bit tables for long-range coulomb (src/kspace.cpp:342)
G vector (1/distance) = 0.2053412
grid = 1250 225 216
stencil order = 5
estimated absolute RMS force accuracy = 0.00040335986
estimated relative force accuracy = 1.2147062e-06
using double precision KISS FFT
3d grid and FFT values/proc = 326025 262500
Generated 0 of 10 mixed pair_coeff terms from geometric mixing rule
Neighbor list info ...
update every 1 steps, delay 0 steps, check yes
max neighbors/atom: 10000, page size: 100000
master list distance cutoff = 17
ghost atom cutoff = 17
binsize = 8.5, bins = 353 37 34
2 neighbor lists, perpetual/occasional/extra = 2 0 0
(1) pair table, perpetual
attributes: half, newton on
pair build: half/bin/newton
stencil: half/bin/3d
bin: standard
(2) pair coul/long, perpetual, copy from (1)
pair build: copy
stencil: none
bin: none
Setting up Verlet run ...
Unit style : real
Current step : 0
Time step : 1
Per MPI rank memory allocation (min/avg/max) = 44.44 | 143.5 | 1173 Mbytes
Step Volume Temp Press PotEng KinEng TotEng E_pair E_vdwl E_coul E_long E_mol E_bond E_angle E_dihed E_impro Enthalpy Density Lx Ly Lz Pxx Pyy Pzz Pxy Pxz Pyz
0 2.6523283e+08 300 2.6378495 36946112 2202093.1 39148205 24758992 -1612261.7 48038374 -21667120 12187119 1360311.1 9412618.8 1140727.5 273462.1 39158408 0.16306379 2994.2991 311.11387 284.71656 6.2742822 -1.788931 3.4281972 -6.1787536 2.3116831 -4.8885717
10 2.6523283e+08 299.83626 9.98711 36947763 2200891.2 39148654 24756707 -1612208.7 48036376 -21667461 12191056 1367223.6 9411297.1 1140045.1 272490.62 39187286 0.16306379 2994.2991 311.11387 284.71656 13.895924 4.5831824 11.482224 -2.2163294 3.6003759 -0.78603315
20 2.6523283e+08 299.35759 -11.865279 36951662 2197377.6 39149039 24756739 -1611055.3 48035291 -21667497 12194923 1372391.6 9410431.9 1139068.8 273030.68 39103143 0.16306379 2994.2991 311.11387 284.71656 -19.61508 -9.0481286 -6.9326276 -11.11387 3.367963 -1.0031891
30 2.6523283e+08 300.1051 6.995051 36945890 2202864.6 39148755 24756412 -1612260.1 48036355 -21667683 12189478 1365388.9 9413046.2 1138014.1 273028.84 39175813 0.16306379 2994.2991 311.11387 284.71656 0.68808575 12.766271 7.5307965 5.2972384 -1.1891102 9.0455208
40 2.6523283e+08 300.64744 11.652021 36941819 2206845.5 39148664 24758447 -1612456.9 48038482 -21667578 12183371 1359611.1 9414344.2 1137502.1 271914.05 39193736 0.16306379 2994.2991 311.11387 284.71656 15.850939 19.198918 -0.093792836 -1.8595567 -1.6401838 -4.1642158
50 2.6523283e+08 299.9803 -0.51148605 36947190 2201948.5 39149138 24755841 -1612450.1 48035929 -21667638 12191349 1368805.3 9411125.5 1138873.2 272544.65 39147160 0.16306379 2994.2991 311.11387 284.71656 6.6752573 3.5086889 -11.718404 0.94091964 -3.6962051 -3.4800126
60 2.6523283e+08 299.59605 -4.6459544 36950281 2199128 39149409 24753148 -1613406.4 48034191 -21667636 12197132 1369112.1 9415164 1140071.1 272785.01 39131437 0.16306379 2994.2991 311.11387 284.71656 -1.2714564 -3.1252101 -9.5411966 0.50867841 -7.2430187 -1.0823207
Loop time of 277.024 on 256 procs for 60 steps with 2462523 atoms
Performance: 0.019 ns/day, 1282.517 hours/ns, 0.217 timesteps/s
98.5% CPU use with 256 MPI tasks x 1 OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0.00054973 | 18.851 | 226 |1338.0 | 6.80
Bond | 0.00027961 | 0.1617 | 1.9056 | 122.2 | 0.06
Kspace | 40.228 | 248.53 | 267.65 | 370.8 | 89.72
Neigh | 6.3795 | 6.5304 | 6.5617 | 1.6 | 2.36
Comm | 0.00031963 | 0.20402 | 1.9467 | 102.8 | 0.07
Output | 0.68858 | 0.70533 | 0.72528 | 1.0 | 0.25
Modify | 0.27414 | 1.6694 | 2.0285 | 39.4 | 0.60
Other | | 0.3691 | | | 0.13
Nlocal: 9619.23 ave 106790 max 0 min
Histogram: 232 0 0 0 0 0 0 0 8 16
Nghost: 13308.5 ave 151654 max 0 min
Histogram: 224 0 8 0 0 0 8 0 8 8
Neighs: 9.88618e+06 ave 1.13329e+08 max 0 min
Histogram: 232 0 0 0 0 0 0 8 0 16
Total # of neighbors = 2.5308608e+09
Ave neighs/atom = 1027.7511
Ave special neighs/atom = 5.4285714
Neighbor list builds = 2
Dangerous builds = 0
System init for write_data ...
grid = 1250 225 216
stencil order = 5
1a
1b
1c
1d
2
Iteration Number: 1
4
