Hi. I want to install LAMMPS on GPU. My GPU is RTX 3090. LAMMPS version is 2020. i use cmake. when I execute “make -j20”, the following error occurs:
nvcc fatal : Unsupported gpu architecture ‘compute_30’
CMake Error at cuda_compile_fatbin_1_generated_lal_pppm_f.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_pppm_f.cu.fatbin
CMake Error at cuda_compile_fatbin_1_generated_lal_born_coul_wolf.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_born_coul_wolf.cu.fatbin
[ 2%] Building CXX object CMakeFiles/nvc_get_devices.dir/opt/lammps3marc20gpu/lammps-3Mar20/lib/gpu/geryon/ucl_get_devices.cpp.o
CMake Error at cuda_compile_fatbin_1_generated_lal_beck.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_beck.cu.fatbin
CMake Error at cuda_compile_fatbin_1_generated_lal_atom.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_atom.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:743: cuda_compile_fatbin_1_generated_lal_pppm_f.cu.fatbin] Error 1
make[2]: *** Waiting for unfinished jobs…
CMake Error at cuda_compile_fatbin_1_generated_lal_born.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_born.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:358: cuda_compile_fatbin_1_generated_lal_born_coul_wolf.cu.fatbin] Error 1
make[2]: *** [CMakeFiles/gpu.dir/build.make:330: cuda_compile_fatbin_1_generated_lal_beck.cu.fatbin] Error 1
make[2]: *** [CMakeFiles/gpu.dir/build.make:323: cuda_compile_fatbin_1_generated_lal_atom.cu.fatbin] Error 1
make[2]: *** [CMakeFiles/gpu.dir/build.make:337: cuda_compile_fatbin_1_generated_lal_born.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_born_coul_wolf_cs.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_born_coul_wolf_cs.cu.fatbin
CMake Error at cuda_compile_fatbin_1_generated_lal_born_coul_long.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_born_coul_long.cu.fatbin
CMake Error at cuda_compile_fatbin_1_generated_lal_born_coul_long_cs.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_born_coul_long_cs.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:365: cuda_compile_fatbin_1_generated_lal_born_coul_wolf_cs.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_buck_coul_long.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_buck_coul_long.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:344: cuda_compile_fatbin_1_generated_lal_born_coul_long.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_buck_coul.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_buck_coul.cu.fatbin
CMake Error at cuda_compile_fatbin_1_generated_lal_charmm_long.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_charmm_long.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:351: cuda_compile_fatbin_1_generated_lal_born_coul_long_cs.cu.fatbin] Error 1
make[2]: *** [CMakeFiles/gpu.dir/build.make:379: cuda_compile_fatbin_1_generated_lal_buck_coul.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_buck.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_buck.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:386: cuda_compile_fatbin_1_generated_lal_buck_coul_long.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_colloid.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_colloid.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:393: cuda_compile_fatbin_1_generated_lal_charmm_long.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_coul.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_coul.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:372: cuda_compile_fatbin_1_generated_lal_buck.cu.fatbin] Error 1
make[2]: *** [CMakeFiles/gpu.dir/build.make:400: cuda_compile_fatbin_1_generated_lal_colloid.cu.fatbin] Error 1
make[2]: *** [CMakeFiles/gpu.dir/build.make:407: cuda_compile_fatbin_1_generated_lal_coul.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_coul_debye.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_coul_debye.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:414: cuda_compile_fatbin_1_generated_lal_coul_debye.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_coul_long.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_coul_long.cu.fatbin
CMake Error at cuda_compile_fatbin_1_generated_lal_coul_dsf.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_coul_dsf.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:428: cuda_compile_fatbin_1_generated_lal_coul_long.cu.fatbin] Error 1
make[2]: *** [CMakeFiles/gpu.dir/build.make:421: cuda_compile_fatbin_1_generated_lal_coul_dsf.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_coul_long_cs.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_coul_long_cs.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:435: cuda_compile_fatbin_1_generated_lal_coul_long_cs.cu.fatbin] Error 1
CMake Error at cuda_compile_fatbin_1_generated_lal_device.cu.fatbin.RelWithDebInfo.cmake:214 (message):
Error generating
/opt/lammps3marc20gpu/lammps-3Mar20/build/cuda_compile_fatbin_1_generated_lal_device.cu.fatbin
make[2]: *** [CMakeFiles/gpu.dir/build.make:442: cuda_compile_fatbin_1_generated_lal_device.cu.fatbin] Error 1
make[2]: Leaving directory ‘/opt/lammps3marc20gpu/lammps-3Mar20/build’
make[1]: *** [CMakeFiles/Makefile2:206: CMakeFiles/gpu.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[ 3%] Linking CXX executable nvc_get_devices
[ 3%] Built target nvc_get_devices
make[1]: Leaving directory ‘/opt/lammps3marc20gpu/lammps-3Mar20/build’
make: *** [Makefile:130: all] Error 2
