Dear LAMMPS users,
I am a new user in laammps (for about two months). I have read many prior emails and I found them very useful.
I alread installed LAMMPS on my windows machine and there was no problem and I using cygwin as Linux interface. But when I tried to install it on the supercomputer, there are some problems. Actually, when I installed lammps with default or nor,al packages there was no problem. Now, I need to add more packages such as dipole, User-misc, and kspace.
My steps are:
- download lammps and copy the tar file in my SSH account on my school supercomputer, then un-tar the file via: tar -xzvf lammps.tar.gz
then, I turned one some packages when I am in the scr directory via: make yes-dipole and so on
I checked these packages via: make packages-status
Finally, I installed lammps via: make -j8 mpi
I saw two types of errors which is not mentioned in the mailing list.
Dear LAMMPS users,
mpicxx -g -O3 -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64 -DMPICH_SKIP_MPICXX
-DOMPI_SKIP_MPICXX=1 -c ../pair_list.cpp
../pair_list.cpp(88): error: expected a ";"
const dbl3_t * _noalias const x = (dbl3_t *) atom->x[0];
../pair_list.cpp(89): error: "restrict" has already been declared in the
current scope
dbl3_t * _noalias const f = (dbl3_t *) atom->f[0];
this is known and documented and has been answered on the mailing list
several times. you are compiling with intel compilers and thus must add the
-restrict flag to CCFLAGS.
Dear Professor Axel:
I did what you said as you can see here. This is where I added “-restrict”
compiler/linker settings
specify flags and libraries needed for your compiler
CC = mpicxx
CCFLAGS = -g -O3 -restrict
SHFLAGS = -fPIC
DEPFLAGS = -M
I did what you said as you can see here. This is where I added "-restrict"
# compiler/linker settings
# specify flags and libraries needed for your compiler
CC = mpicxx
SHFLAGS = -fPIC
DEPFLAGS = -M
but I saw this error when I compile lammps
ermo.o timer.o universe.o update.o variable.o velocity.o verlet.o
write_coeff.o write_data.o write_dump.o write_restart.o -o ../lmp_mpi
/usr/global/intel/Compiler/11.1/046/lib/intel64/libimf.so: warning:
warning: feupdateenv is not implemented and will always fail
this is a warning, not an error.
size ../lmp_mpi
text data bss dec hex filename
9303125 196672 17128 9516925 91377d ../lmp_mpi
make[1]: warning: Clock skew detected. Your build may be incomplete.
this is a warning, not an error. have you tested the resulting
executable? either your home directory is mounted on a networked file
system, where the time on the file server is not synchronized with a proper
time server, or the time on your machine is set (way?) back.
make[1]: Leaving directory `/home1/hemedaaa/lammps-17Nov16/src/Obj_mpi'
[[email protected]... src] cd
\[hemedaaa@\.\.\.6729\.\.\. \~\] cd lammps-17Nov16/src/
[[email protected]... src] make clean\-all
rm \-rf Obj\_\*
\[hemedaaa@\.\.\.6729\.\.\. src\] cd
[[email protected]... ~]$ rm -r lammps-17Nov16/
this is just deleting everything. why?
