Hi again,
I'm currently trying to figure out exactly how the program flow proceeds in
LAMMPS when the lammps_command(ptr, "run 0") method is executed using the
library interface.
I looked at the source files, and I see that it calls the input->one()
method, which in turn calls input->execute_command(), but that method
doesn't seem to have a run action listed in its decision tree. Could someone
point me to where this specific command branches so I can discover exactly
what other functions, etc. get invoked along the way?
part of the magic happens due to this construct.
#define COMMAND_CLASS
#define CommandStyle(key,Class) \
else if (strcmp(command,#key) == 0) { \
Class key(lmp); \
key.command(narg,arg); \
return 0; \
#include "style_command.h"
#undef COMMAND_CLASS
this includes additional commands that can be added at compile time
without changing a line of the remaining code. check this out:
[[email protected]... src]$ grep CommandStyle *.h
balance.h:CommandStyle(balance,Balance)
change_box.h:CommandStyle(change_box,ChangeBox)
create_atoms.h:CommandStyle(create_atoms,CreateAtoms)
create_box.h:CommandStyle(create_box,CreateBox)
delete_atoms.h:CommandStyle(delete_atoms,DeleteAtoms)
delete_bonds.h:CommandStyle(delete_bonds,DeleteBonds)
displace_atoms.h:CommandStyle(displace_atoms,DisplaceAtoms)
group_ndx.h:CommandStyle(group2ndx,Group2Ndx)
minimize.h:CommandStyle(minimize,Minimize)
neb.h:CommandStyle(neb,NEB)
prd.h:CommandStyle(prd,PRD)
read_data.h:CommandStyle(read_data,ReadData)
read_dump.h:CommandStyle(read_dump,ReadDump)
read_restart.h:CommandStyle(read_restart,ReadRestart)
replicate.h:CommandStyle(replicate,Replicate)
rerun.h:CommandStyle(rerun,Rerun)
run.h:CommandStyle(run,Run)
set.h:CommandStyle(set,Set)
tad.h:CommandStyle(tad,TAD)
temper.h:CommandStyle(temper,Temper)
velocity.h:CommandStyle(velocity,Velocity)
write_data.h:CommandStyle(write_data,WriteData)
write_dump.h:CommandStyle(write_dump,WriteDump)
write_restart.h:CommandStyle(write_restart,WriteRestart)
there you see the run command.
