Hi
I wanted to install lammps parallel according to lammps sites’s instructions.
but after installing packages and run an example parallel I got this error:
It looks like MPI_INIT failed for some reason; your parallel process is
likely to abort. There are many reasons that a parallel process can
fail during MPI_INIT; some of which are due to configuration or environment
problems. This failure appears to be an internal failure; here’s some
additional information (which may only be relevant to an Open MPI
developer):
ompi_mpi_init: orte_init failed
–> Returned “A system-required executable either could not be found or was not executable by this user” (-127) instead of “Success” (0)
              This is an MPI problem, not a LAMMPS problem.
I suggest you find a local expert to help you.
              Though as Steve said, though not related to the error you are having
I've attached a makefile I've been using which seems to work for me.
(I stole this makefile from the ubuntu forums.  Copy it into the
src/MAKE/ directory.)
I've read some ubuntu users complain about MPI problems after
upgrading from an earlier version of ubuntu. If it helps, I'm running
this on a fresh installation of ubuntu 11.10  (I had to install these
additional packages:  mpich2, build-essential, fftw-dev, gfortran,
g++)  Anyway, this works on a multi-core desktop.  (I don't have a
cluster to test it on at the moment.)
Cheers
Andrew
Makefile.ubuntu_parallel.txt (649 Bytes)
Makefile.ubuntu_serial (649 Bytes)
