I am simulating a atomistic polymer system -diblock PSS-PEP.
Below is the input script.
I want to know I am running this with CPUs(no kokkos) and is that ok if I keep newton on in input script.
Will that affect the simulation out put?
log lammps.nve
units real
newton on
#package gpu 2
neigh_modify delay 5 every 1 one 10000
#neigh_modify delay 0 every 1 check yes
#processors 4 2 2
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style opls
#improper_style cvff
special_bonds lj 0.0 0.0 0.5
pair_style lj/cut 12.0
#kspace_style pppm 1.0e-4
#kspace_modify mesh 20 20 20
read_data PSS15PEPNa6.data
#read_restart restart_2nvelim remap
reset_timestep 0
#replicate 2 1 1
#write_data PSS9_melt.data
#fix 1 all recenter 0.0 0.0 0.0 units box
#velocity all create 300.0 330083
#fix 1 all nvt temp 300.0 300.0 100
#fix 1 all npt temp 600.0 600.0 100 iso 10.0 10.0 100.0
#group polymer type 1 2 3 4 5 6 7 8
#group one molecule 50 51 94 95 109 110 155
compute 2 polymer gyration
compute 3 center gyration
dielectric 1
fix 1 all nve/limit 0.1
fix 1 all nve
fix 2 all langevin 500.0 500.0 100.0 11434267
#fix 3 polymer freeze
#variable r equal ramp(1200,1200)
#fix 3 polymer indent 100 sphere 0.0 0.0 0.0 140.0 side in units box
#fix 3 all balance 100 xyz 10 1.05 out tmp.balance
#fix 4 all deform 1 x final -150 150 y final -150 150 z final -150 150 units box
#fix 3 all recenter 0.0 0.0 0.0 units box
#fix 2 water shake 0.001 20 0 b 15 a 27
fix 10 all momentum 1 linear 1 1 1
#delete_atoms group one compress yes bond yes mol yes
#displace_atoms nafive move -150 -100 -100
thermo 1000
thermo_style custom step temp press vol density cpu
#thermo_modify flush yes
timestep 1
#reset_timestep 0
#run_style respa 2 4 pair 1 kspace 2
restart 100000 restart_1nvelim restart_2nvelim
dump 1 polymer custom 250000 PSS9_THF6_COM.18a id type xs ys zs ix iy iz
dump 2 all custom 100000 PSS15PEP_nvelim id type xs ys zs ix iy iz mol
run 1000000
