Hello everybody.
I’m recently facing weird errors for outputs of the “calculate property/atom” command. I use “fix ave/time” to log the data calculated by the following command:
compute 3V ACID property/atom vx vy vz
fix c3V all ave/time10 1 10 c_3V file ACID.Vel mode vector
The problem is that no syntax of different modes of vector or scalar works. Also, I tried to change c_3V[1] c_3V[2] c_3V[3] only to c_3V and other formats to check which one eventually works but none of them helped. I would be thankful if you just guide me to fix this and I learn how to make outputs for the mentioned compute command.
