Dear lammps users
Sorry for the basic question, I’m trying to run LAMMPS parallelly using openmp on mac os. But, there is some error. How can I solve this problem? Any advice is very much appreciated.
This is my error
Per MPI rank memory allocation (min/avg/max) = 24.69 | 24.89 | 25.16 Mbytes
Step Temp PotEng KinEng TotEng Press Volume
0 3000 -6530.6253 795.87628 -5734.749 -11461.69 15625
10000 3062.1929 -6818.0478 812.37558 -6005.6722 1288.8264 15625
[Jongwunui-MacBookPro:63186] *** Process received signal ***
[Jongwunui-MacBookPro:63186] Signal: Segmentation fault: 11 (11)
[Jongwunui-MacBookPro:63186] Signal code: Address not mapped (1)
[Jongwunui-MacBookPro:63186] Failing at address: 0x7fec7b506a70
[Jongwunui-MacBookPro:63186] [ 0] 0 libsystem_platform.dylib 0x00007fff63b9f42d _sigtramp + 29
[Jongwunui-MacBookPro:63186] [ 1] 0 ??? 0x0000000000000008 0x0 + 8
[Jongwunui-MacBookPro:63186] [ 2] 0 lmp_omp 0x0000000104f637f1 _ZN9LAMMPS_NS10PairReaxFF7computeEii + 369
[Jongwunui-MacBookPro:63186] [ 3] 0 lmp_omp 0x0000000104d79fc2 _ZN9LAMMPS_NS6Verlet3runEi + 994
[Jongwunui-MacBookPro:63186] [ 4] 0 lmp_omp 0x0000000104d29513 _ZN9LAMMPS_NS3Run7commandEiPPc + 2563
[Jongwunui-MacBookPro:63186] [ 5] 0 lmp_omp 0x0000000104be229a _ZN9LAMMPS_NS5Input15execute_commandEv + 1770
[Jongwunui-MacBookPro:63186] [ 6] 0 lmp_omp 0x0000000104be142e _ZN9LAMMPS_NS5Input4fileEv + 878
[Jongwunui-MacBookPro:63186] [ 7] 0 lmp_omp 0x00000001049d486d main + 77
[Jongwunui-MacBookPro:63186] [ 8] 0 libdyld.dylib 0x00007fff639a67fd start + 1
[Jongwunui-MacBookPro:63186] [ 9] 0 ??? 0x0000000000000003 0x0 + 3
[Jongwunui-MacBookPro:63186] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 3 with PID 0 on node Jongwunui-MacBookPro exited on signal 11 (Segmentation fault: 11).
lmp_omp information
OS: Darwin 19.2.0 x86_64
Compiler: Clang C++ Homebrew Clang 13.0.0 with OpenMP 5.0
C++ standard: C++11
MPI v3.1: Open MPI v4.1.2, package: Open MPI brew@iMac-Pro Distribution, ident: 4.1.2, repo rev: v4.1.2, Nov 24, 2021
Accelerator configuration:
OPENMP package API: OpenMP
OPENMP package precision: double
Build information
cmake -C …/cmake/presets/basic.cmake -D PKG_OPENMP=on -D CMAKE_INSTALL_PREFIX=’/Users/jongwuni/opt/anaconda3/envs/MD’ -D LAMMPS_MACHINE=omp …/cmake
– <<< Build configuration >>>
Operating System: Darwin
Build type: RelWithDebInfo
Install path: /Users/jongwuni/opt/anaconda3/envs/MD
Generator: Unix Makefiles using /usr/bin/make
– Enabled packages: KSPACE;MANYBODY;MOLECULE;OPENMP;REAXFF;RIGID
– <<< Compilers and Flags: >>>
– C++ Compiler: /usr/local/opt/llvm/bin/clang++
Type: Clang
Version: 13.0.0
C++ Flags: -O2 -g -DNDEBUG
Defines: LAMMPS_SMALLBIG;LAMMPS_MEMALIGN=64;LAMMPS_OMP_COMPAT=4;LAMMPS_JPEG;LAMMPS_PNG;LAMMPS_GZIP;FFT_FFTW3;FFT_FFTW_THREADS;LMP_OPENMP
– <<< Linker flags: >>>
– Executable name: lmp_omp
– Executable linker flags: -L/usr/local/opt/llvm/lib
– Static library flags:
– <<< MPI flags >>>
– MPI_defines: MPICH_SKIP_MPICXX;OMPI_SKIP_MPICXX;_MPICC_H
– MPI includes: /usr/local/Cellar/open-mpi/4.1.2/include
– MPI libraries: /usr/local/Cellar/open-mpi/4.1.2/lib/libmpi.dylib;
– <<< FFT settings >>>
– Primary FFT lib: FFTW3
– Using double precision FFTs
– Using threaded FFTs
– Configuring done
– Generating done
– Build files have been written to: /Users/jongwuni/Documents/LAMMPS/lmp_source/lammps/build
Best regards
Jongwun
