Hi all,
I am using LAMMPS for SPH. But my questions are general. I am trying to simulate a massive particle that would drop on a bed of water, so there can be 2 conditions: 1) the particle will displace some molecules of water resulting in splashes (as we see in the water collapse example) 2) the particle may diffuse with the water.
For the start, I am trying to simulate the first condition only. But my particle is just sliding over water molecules and water molecules do not displace at all.
My questions are:
i- I created water molecules in a region - is there any way I can remove the restriction of the region from water molecules so that they can move when hit by a particle?
ii- Can I specify the size/ diameter of the particle atoms?
iii- My last question is how can I make a read_data file to define the properties and initial position of the atoms/molecules.
I am sharing my input script here.
##24082022
#====INITIALISATION====#
processors * * *
units lj
atom_style sph
region box block 0 50 0 50 0 50 units lattice
create_box 2 box
## ------------- System definition ------------- ###
region water cylinder z 20 20 10 INF INF
create_atoms 1 random 10000 341341 water #create 10000 atoms of type 1 in the region "water"
create_atoms 2 random 1 127569 water #create 150 atoms of type 2 in the region "mycylin"
### ------------- Simulation settings ------------- ###
mass 1 18 ###attribute a mass of 18 (unitless) to atoms of type 1
mass 2 60 ###attribute a mass of 60 (unitless) to atoms of type 2
group water type 1
group particle type 2
variable h equal 0.03
variable c equal 10.0 # soundspeed for Tait's EOS
variable dt equal 0.1*${h}/${c} # upper limit of timestep based on CFL-like criterion
pair_style hybrid/overlay sph/taitwater/morris sph/rhosum 100 lj/cut ${h}
pair_coeff * * sph/taitwater/morris 1000.0 ${c} 1.0e-3 ${h} # use target density of 1000, soundspeed ${c} for Tait's EOS
pair_coeff * * sph/rhosum ${h}
pair_coeff * * lj/cut 0.005 ${h}
neigh_modify every 5 delay 0 check yes
# time-integrate position, velocities, internal energy and density of inserted particles and water
fix fix1 all sph
fix gfix particle gravity -9.81 vector 0 0 1 # add gravity. This fix also computes potential energy of mass in gravity field.
#fix ID group-ID drag x y z fmag delta
fix dragfix particle drag 0 0 200 100 0
compute rho_peratom all sph/rho/atom
compute e_peratom all sph/e/atom
compute esph all reduce sum c_e_peratom
compute ke all ke
variable etot equal c_esph+c_ke+f_gfix
# adjust nevery | min. allowed dt | max. allowed dt | max. travel distance per dt # // ${dt} ~= CFL criterion 0.1*h/c
fix dtfix all dt/reset 1 NULL ${dt} 0.005 units box # use a variable timestep
dump dump_id1 all custom 100 combined.lammpstrj id type xs ys zs c_rho_peratom c_e_peratom fx fy fz
dump dump_id2 all xyz 100 combined.xyz
dump_modify dump_id1 first yes
thermo 100
thermo_style custom step ke c_esph v_etot f_gfix press time f_dtfix
thermo_modify norm no
timestep 0.005
run 10000
Many thanks
