I am using AdvanceSoftCorp version of LAMMPS https://github.com/advancesoftcorp/lammps using the most recent branch: based-on-lammps_2Aug2023. Using this version for support of MatGL, which has support for CUDA. I have a custom Python3 installation with MatGL and all of it’s dependencies needed for CUDA support. MatGL tests work. Adding ASE https://pypi.org/project/ase/ into the Python3 build doesn’t appear to break anything when running Python shell from this location.
LAMMPS throws errors when loading Python. Errors appear to be with loading of NumPy.
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/core/__init__.py", line 24, in <module>
from . import multiarray
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/core/multiarray.py", line 10, in <module>
from . import overrides
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/core/overrides.py", line 8, in <module>
from numpy.core._multiarray_umath import (
ImportError: /data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/core/_multiarray_umath.cpython-310-x86_64-linux-gnu.so: undefined symbol: PyObject_SelfIter
During handling of the above exception, another exception occurred:
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/__init__.py", line 130, in <module>
from numpy.__config__ import show as show_config
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/__config__.py", line 4, in <module>
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/core/__init__.py", line 50, in <module>
raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.10 from "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/bin/python3"
* The NumPy version is: "1.26.3"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: /data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/core/_multiarray_umath.cpython-310-x86_64-linux-gnu.so: undefined symbol: PyObject_SelfIter
The above exception was the direct cause of the following exception:
File "/data/tools/build/ubuntu_22.04/lammps/asc_2Aug2023_matgl0.9.1_cuda118/01_test_lammps/./matgl_driver.py", line 33, in <module>
from ase import Atoms
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/ase/__init__.py", line 17, in <module>
from ase.atom import Atom
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/ase/atom.py", line 3, in <module>
import numpy as np
File "/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/site-packages/numpy/__init__.py", line 135, in <module>
raise ImportError(msg) from e
ImportError: Error importing numpy: you should not try to import numpy from
its source directory; please exit the numpy source tree, and relaunch
When loading this install of Python3, I can load NumPy without issue and run self tests. When calling from LAMMPS, the Python environment has issues finding it’s own modules. I suspect PYTHONPATH and PYTHONHOME envvars may be able to solve this- but have not been able to resolve yet.
Additional information:
I modified the matgl_driver.py to dump several envvars for debugging when LAMMPS calls Python.
Copyright (c) 2023, AdvanceSoft Corp.
This source code is licensed under the GNU General Public License Version 2
found in the LICENSE file in the root directory of this source tree.
# print several envvars / help with debugging
import os
import sys
print( "PYTHONHOME:" )
print( " %s" % ( os.environ.get( 'PYTHONHOME' ) ) )
print( "PYTHONPATH:" )
if os.environ.get( 'PYTHONPATH' ):
for item in os.environ.get( 'PYTHONPATH' ).split( ':'):
print( " %s" % ( item ) )
else:
print( " %s" % ( os.environ.get( 'PYTHONPATH' ) ) )
print( "PATH:" )
for item in os.environ.get( 'PATH' ).split( ':' ):
print( "sys.path:")
for item in sys.path:
from ase.calculators.mixing import SumCalculator
import matgl
from matgl.ext.ase import M3GNetCalculator
def m3gnet_initialize(model_name = None, dftd3 = False):
Initialize GNNP of M3GNet.
Args:
model_name (str): name of model for GNNP.
dftd3 (bool): to add correction of DFT-D3.
Returns:
cutoff: cutoff radius.
# Create M3GNetCalculator, that is pre-trained
global myCalculator
if model_name is not None:
myPotential = matgl.load_model(model_name)
else:
myPotential = matgl.load_model("M3GNet-MP-2021.2.8-PES")
myCalculator = M3GNetCalculator(
potential = myPotential,
compute_stress = True,
stress_weight = 1.0
# Add DFT-D3 to calculator without three-body term
global m3gnetCalculator
global dftd3Calculator
m3gnetCalculator = myCalculator
dftd3Calculator = None
if dftd3:
from dftd3.ase import DFTD3
#from torch_dftd.torch_dftd3_calculator import TorchDFTD3Calculator
dftd3Calculator = DFTD3(
method = "PBE",
damping = "d3zero",
s9 = 0.0
#dftd3Calculator = TorchDFTD3Calculator(
# xc = "pbe",
# damping = "zero",
# abc = False
myCalculator = SumCalculator([m3gnetCalculator, dftd3Calculator])
# Atoms object of ASE, that is empty here
global myAtoms
myAtoms = None
return myPotential.model.cutoff
def m3gnet_get_energy_forces_stress(cell, atomic_numbers, positions):
Predict total energy, atomic forces and stress w/ pre-trained GNNP of M3GNet.
Args:
cell: lattice vectors in angstroms.
atomic_numbers: atomic numbers for all atoms.
positions: xyz coordinates for all atoms in angstroms.
Returns:
energy: total energy.
forcces: atomic forces.
stress: stress tensor (Voigt order).
# Initialize Atoms
global myAtoms
global myCalculator
if myAtoms is not None and len(myAtoms.numbers) != len(atomic_numbers):
myAtoms = None
if myAtoms is None:
myAtoms = Atoms(
numbers = atomic_numbers,
positions = positions,
cell = cell,
pbc = [True, True, True]
myAtoms.calc = myCalculator
else:
myAtoms.set_cell(cell)
myAtoms.set_atomic_numbers(atomic_numbers)
myAtoms.set_positions(positions)
# Predicting energy, forces and stress
energy = myAtoms.get_potential_energy().item()
forces = myAtoms.get_forces().tolist()
if dftd3Calculator is None:
stress = myAtoms.get_stress().tolist()
else:
# to avoid the bug of SumCalculator
myAtoms.calc = m3gnetCalculator
stress1 = myAtoms.get_stress()
myAtoms.calc = dftd3Calculator
stress2 = myAtoms.get_stress()
stress = stress1 + stress2
stress = stress.tolist()
return energy, forces, stress
When running example- I get following errors:
pair_style m3gnet ./matgl_driver.py # MatGL python driver script
pair_coeff * * M3Gnet-MP-2021.2.8-PES Au # specify GNN parameter checkpoint file
PYTHONHOME:
None
PYTHONPATH:
None
PATH:
/usr/local/sbin
/usr/local/bin
/usr/sbin
/usr/bin
/sbin
/bin
/usr/games
/usr/local/games
/snap/bin
sys.path:
/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python310.zip
/data/tools/target/ubuntu_22.04/python/3.10.13_matgl_0.9.1_cuda_11.8/lib/python3.10/lib-dynload
./matgl_driver.py
ERROR: Cannot initialize python for pair_coeff of M3GNet. (src/ML-M3GNET/pair_m3gnet.cpp:490)
Last command: pair_coeff * * M3Gnet-MP-2021.2.8-PES Au # specify GNN parameter checkpoint file
I’ve found that the error message is pretty generic from LAMMPS when Python dumps a stack trace, but including this as it shows envvars [search paths] that were available from within Python as it was called by LAMMPS and the matgl_driver.py.
NumPy appears to work when Python is called, but when Python is called from LAMMPS- it has trouble finding NumPy.
Any insights or suggestions appreciated.
