LAMMPS Reading Unrealistically Large Atom Count from Atomsk-Generated File
I’m using Atomsk to generate a cylindrical sample and reading it into LAMMPS using the read_data command. The model should contain around 1.6 million atoms, but occasionally, LAMMPS reads a completely nonsensical number of atoms—something like 140730947889715—and then hangs indefinitely.
Strangely, if I cancel the job and re-run the exact same script and data file, it often works perfectly without any changes. This suggests the issue is intermittent and not a problem with the data file itself.
To help debug this, I’ve attached:
• The LAMMPS input script (in.creatGB_cyln_CoAl_fccAl.txt)
• The LAMMPS output file from a failed run (Outrerunpolycrystal.o4619145)
in.creatGB_cyln_CoAl_fccAl.txt (3.3 KB)
Outrerunpolycrystal.o4619145 (438 Bytes)
Here is an excerpt of the cylindrical_sample_coal1.lmp data file generated by Atomsk:
Bcc CoAl alloy oriented X=[001] Y=[1-10] Z=[110].
 1692799  atoms
       2  atom types
  0.000000000000     235.832000000000  xlo xhi
  0.000000000000     333.516812840000  ylo yhi
  0.000000000000     467.736993620000  zlo zhi
Masses
        1   58.93319500             # Co
        2   26.98153860             # Al
Atoms # atomic
     1    1      103.412091451360      50.676292171009       1.928437528366
     2    2      104.853965941040      50.679617333633      -0.104155673739
     3    1      106.290854942240      50.677853029693       1.930397346369
     4    2      107.732510108160      50.681094813114      -0.102167791516
     5    1      109.169491083840      50.679423893881       1.932478775991
     6    2      110.610936359280      50.682575627763      -0.100086361895
     7    1      112.047981009600      50.680984752566       1.934653753011
     8    2      113.489230544480      50.684049772076      -0.097930094354
Has anyone else experienced this kind of erratic behavior with read_data in LAMMPS?
Any insight would be appreciated. Thanks!
No.
Try using
boundary f f p
What is the output of lmp -h ?
The boundary change doesn’t work. Get this for lmp -h (attached).
output (10.4 KB)
There is not much that can be done from remote.
Some suggestions:
  • update to version 12Jun2025 or the latest development branch
  • ditch the Intel compilers and use GCC instead
  • compile LAMMPS with -fsanitize=address or -fsanitize=address (should work with GCC and Clang) and run the input and report any sanitizer messages. Don’t forget the -g flag (and best optimized with -Og instead of -O2 or -O3) so we can get reliable line numbers with any reported issues
  • if you have the patience, with valgrind and report uninitialized memory access or out-of-bounds read and similar that is reported by the memory checker.
Unless you can reproduce this with a much smaller input, I won’t have resources suitable for debugging this kind of stuff.
