lammps reax/c simulation stopped updation without reporting any errors
Dear lammps experts,
I run a reax/c simulation between water and metal by the following 2 steps. The initial configuration may look like the attached figure.
(1)50000 timesteps NVT for the equilibration of metal only;
(2)100000 timesteps NPT reactive MD between water and metal;
However, when the NVT finished and the simulation entered NPT, it halted at 53732ed timestep without reporting any errors. It just stopped updating from the 53732ed timestep as follows:
Step = 53731 Time = 195.2 Atoms = 7534
Temp = 599.8 Press = 139 PotEng = -78.62
KinEng = 1.788 TotEng = -76.83 E_pair = -78.62
v_eb = -1.23e+06 v_ea = 3.341e+05 v_elp = -5.478e-06
v_emol = 0 v_ev = 2170 v_epen = 3.525e-12
v_ecoa = 0 v_ehb = -1712 v_et = 7.523
v_eco = 0 v_ew = 3.235e+05 v_ep = -8.017e+04
v_efi = 0 v_eqeq = 5.947e+04 c_reax = -78.62
---------------- Step 53732 ----- CPU = 1908.5160 (sec) ----------------
Step = 53732 Time = 195.5 Atoms = 7534
Temp = 600.1 Press = 139.1 PotEng = -78.62
v_eb = -1.23e+06 v_ea = 3.341e+05 v_elp = -5.208e-06
v_emol = 0 v_ev = 2172 v_epen = 3.63e-12
v_ecoa = 0 v_ehb = -1713 v_et = 7.582
v_eco = 0 v_ew = 3.235e+05 v_ep = -8.018e+04
What is possible reasons for such strange phenomenon.
Any advice can be highly appreciated,
Thanks in advance,
Xiaolong from Korea Aerospace University
Is it reproducible? If you run it again, does it stop on the same timestep?
It probably will not fail at the same point. I have seen this problem on a number of occasions using reax/c. That is why I only use the KOKKOS package reax.
Jim Kress
