LAMMPS Simulation Help: Troubleshooting High Thermal Conductivity and Other Issues
Hey everyone,
I’m working on a LAMMPS simulation to calculate thermal conductivity using the Green-Kubo method with an MLIP (machine-learned interatomic potential) for a Mg-Bi system. I’m encountering an issue where my calculated thermal conductivity is about two orders of magnitude higher than expected (e.g., ~100-1000 W/mK instead of ~1-10 W/mK for similar materials). I’ve attached my LAMMPS input script and Python processing script below for reference.
Mg3Bi2 simulation
clear
atom_style atomic
read_data lammps_pattern.data
timestep 0.001
neighbor 2.0 nsq
variable boxx equal xhi
variable boxy equal yhi
mass 1 24.305
mass 2 208.980
MTP potential
pair_style mlip mlip.ini
pair_coeff * *
thermo 100
thermo_style custom step temp pe ke etotal press pxx pyy pzz pxy
Compute and print desired thermodynamic information
dump 1 all custom 10000 dump_min.lammpstrj id type x y z
dump_modify 1 sort id
thermo_style custom step pe ke temp pxx pyy pxy pzz xlo xhi ylo yhi fmax fnorm
thermo 1000
min_style fire
minimize 0 1e-10 100000 100000
undump 1
reset_timestep 0
Equilibration Stage 1
Assign initial velocities
variable temp equal 300.0
variable temp2 equal 2*{temp} variable nfreq equal 10000 variable runtime equal 100*{nfreq}
velocity all create ${temp} 41663
Do NVT
dump 1 all custom 10000 dump_NVT.lammpstrj id type x y z
fix 1 all nvt temp {temp} {temp} 1.0
run ${runtime}
undump 1
write_restart nvt.restart
reset_timestep 0
Store heat flux
variable nev equal 1
variable nrep equal 1
variable nfreq0 equal 10000
variable runtime equal 600*${nfreq0}
compute myKE all ke/atom
compute myPE all pe/atom
compute myStress all centroid/stress/atom NULL virial
compute myStress all stress/atom NULL virial
compute 5 all heat/flux myKE myPE myStress
fix JJ all ave/time {nev} {nrep} ${nfreq} c_5[1] c_5[2] c_5[3] file J0Jt.dat ave one
run
thermo {nfreq0} run {runtime}
Python post processing script
gk_publishable_plots_parallel.py
import numpy as np
import matplotlib.pyplot as plt
from scipy.signal import correlate
from concurrent.futures import ProcessPoolExecutor
import inspect
import json
from scipy.io import savemat
import time
step_times =
start_time = time.time()
def log_step(msg):
current_time = time.time()
elapsed_time = current_time - start_time
step_times.append((msg, elapsed_time))
print(f"Line {inspect.currentframe().f_back.f_lineno}: {msg} (Elapsed: {elapsed_time:.2f} s)")
def compute_k_for_lag(lag, corr_xx, corr_yy, corr_zz, nS):
norm = np.arange(nS, nS - lag, -1)
mid = nS - 1
kx = np.sum(corr_xx[mid:mid + lag] / norm)
ky = np.sum(corr_yy[mid:mid + lag] / norm)
kz = np.sum(corr_zz[mid:mid + lag] / norm)
return kx, ky, kz
def gk_publishable_plots():
log_step(“Setting constants”)
deltaMD = 0.001
vol = 133.5058665981581515*10
kb = 8.617343e-5
theta = 300.0
log_step("Reading J0Jt.dat")
with open('J0Jt.dat', 'r') as f:
    _ = f.readline(); _ = f.readline()
    data = np.genfromtxt(f)
log_step("Transposing and shaping input data")
A1 = data.T
nS = A1.shape[1]
log_step(f"Using {nS} time steps from J0Jt.dat")
log_step("Creating lag vector")
I = np.concatenate((np.arange(2000, 5001, 500), np.arange(10000, 100001, 500)))
tau_ps = I * deltaMD
log_step(f"Correlation window = {tau_ps[-1]:.1f} ps, step = {deltaMD} ps")
#log_step("Creating lag vector")
I = np.concatenate((np.arange(100, 5001, 500), np.arange(6000, 100001, 500)))
log_step("Calculating autocorrelations")
corr_xx = correlate(A1[1], A1[1], mode='full')
corr_yy = correlate(A1[2], A1[2], mode='full')
corr_zz = correlate(A1[3], A1[3], mode='full')
log_step("Running parallel conductivity computation")
results = []
with ProcessPoolExecutor() as executor:
    futures = [executor.submit(compute_k_for_lag, lag, corr_xx, corr_yy, corr_zz, nS) for lag in I]
    for future in futures:
        results.append(future.result())
log_step("Converting results and applying factor")
kcond = np.array(results)
factor = (deltaMD / (vol * kb * theta**2)) * 1602.176
kcond *= factor
log_step("Computing in-plane average")
kinplane = np.mean(kcond[:, 0:2], axis=1, keepdims=True)
kcond = np.hstack((kcond, kinplane))
log_step("Calculating standard deviation")
std_k = np.std(kcond[:, 3])
log_step("Extracting plateau region (15-25 ps)")
idx_low = np.where(tau_ps >= 15)[0][0]
idx_high = np.where(tau_ps <= 25)[0][-1]
k = {
    'kxx': np.mean(kcond[idx_low:idx_high+1, 0]),
    'kyy': np.mean(kcond[idx_low:idx_high+1, 1]),
    'kzz': np.mean(kcond[idx_low:idx_high+1, 2]),
    'k':   np.mean(kcond[idx_low:idx_high+1, 3]),
    'std': np.max(kcond[idx_low:idx_high+1, 3]) - np.min(kcond[idx_low:idx_high+1, 3])
print(f'kxx={k["kxx"]:.2f}, kyy={k["kyy"]:.2f}, kzz={k["kzz"]:.2f}, '
      f'k={k["k"]:.2f} ± {k["std"]:.2f} W/mK')
log_step("Saving conductivity data to thermal_conductivity.txt")
out_k = np.column_stack((tau_ps, kcond))
header_k = 'tau_ps[ps]   k_xx[W/mK]   k_yy[W/mK]   k_zz[W/mK]   k_inplane[W/mK]'
np.savetxt('thermal_conductivity.txt', out_k, header=header_k, fmt='%.6e', comments='')
with open('thermal_conductivity_summary.json', 'w') as jf:
    json.dump(k, jf, indent=4)
log_step("Saved summary dictionary to thermal_conductivity_summary.json")
log_step("Plotting and saving thermal conductivity figure to PDF")
plt.figure()
labels = ['k_xx', 'k_yy', 'k_zz', 'k_inplane']
for i in range(4):
    plt.plot(tau_ps, kcond[:, i], marker='o', label=labels[i])
plt.xlabel('Correlation Time τ_I (ps)')
plt.ylabel('Thermal Conductivity (W/mK)')
plt.legend()
plt.grid(True)
plt.tight_layout()
plt.savefig('thermal_conductivity.pdf')
plt.show()
log_step("Computing normalized HCACF")
Icorr = np.arange(1, 100001, 100)
mid = nS - 1
normHC = corr_xx[mid + Icorr] / corr_xx[mid]
log_step("Saving normalized HCACF to normalized_HCACF.txt")
tau_I = Icorr * deltaMD
out_hcacf = np.column_stack((tau_I, normHC))
header_hcacf = 'tau_ps[ps]   normalized_HCACF'
np.savetxt('normalized_HCACF.txt', out_hcacf, header=header_hcacf, fmt='%.6e', comments='')
log_step("Saving normalized HCACF to normalized_HCACF.mat (backup)")
savemat('normalized_HCACF.mat', {'Icorr': Icorr, 'normHC': normHC})
log_step("Plotting and saving normalized HCACF figure to PDF")
plt.figure()
plt.plot(tau_I, normHC, 's-')
plt.xlabel('τ (ps)')
plt.ylabel('Normalized HCACF')
plt.grid(True)
plt.tight_layout()
plt.savefig('normalized_HCACF.pdf')
plt.show()
log_step("Writing timing log to timing_log.txt")
with open("timing_log.txt", "w") as f:
    f.write("Step Description | Time (s)\n")
    for msg, t in step_times:
        f.write(f"{msg} | {t:.2f}\n")
return k, normHC
if name == “main”:
log_step(“Calling gk_publishable_plots()”)
I would try using your script with another material described by a standard potential (EAM?) with a known thermal conductivity. If your results match with the reference data, that means that the MLIP is the culprit. Otherwise, your script is faulty.
For future reference, please have a look at the forum guidelines post to learn about best practices and how to get the best help here. For example, the script code in your post is messed up and practically unreadable because you are not quoting it correctly. There is also information missing that is usually required for providing meaningful advice. At the moment, you very much limiting the kind of help you can get.
Thank you, Sir.
in.bpn (1.8 KB)
plot_conductivity.py (5.0 KB)
lammps_pattern.data (912.1 KB)
mlip.ini (83 Bytes)
pot.mtp (136.9 KB)
This is my J0Jt.dat file like https://drive.google.com/file/d/191bJXzsVyQ4Ds_RokGFXAXYGDBshv2GZ/view?usp=sharing
Dear Sir,
I uploaded all my files here. So,now everyone can access and see them clearly.
