I got some troubles in simulation water using spc/e model.
The lammps version I used is lammps-11Aug17.
I used “fix rattle” command to impose constraints on bond angle and length (rigid water model) as suggest in lammps example (example/HEAT).
However, when I simulate pure water (NVT) at 300K with “fix rattle” turned on, the water molecules behave kind of frozen and lose their translational motion, but with pretty local fast hydrogen atom vibration. The output temperature and potential energy gradually converge to constant values. However, when I turned of “fix rattle”, everything worked well (losing some constraints on bond angle and length).
Anyone have any suggestion?? (my input file is shown below)
# Solvated 5-mer peptide
units real
atom_style full
variable O equal 1
variable H equal 2
variable cutC equal 10.
variable cutLJ equal 9.
variable epsOO equal 0.15535
variable sigOO equal 3.166
variable theta equal 109.47
variable t equal 300.
read_data data.water #hpht
#read_restart nacl.restart.30000 #nacl.restart.10000
#pair
pair_style lj/cut/coul/long {cutLJ} {cutC}
pair_coeff * * 0.0 0.0
pair_coeff {O} {O} {epsOO} {sigOO}
#Ewald summation with precision 1.e-5
kspace_style ewald 1e-5
# bonds and angle of water
bond_style harmonic
angle_style harmonic
bond_coeff 1 1000.00 1.000
angle_coeff 1 100.0 ${theta}
# use RATTLE with precision 1.e-10
#fix frat all rattle 1e-10 500 0 b 1 a 1
# neighbor skin
neighbor 2.0 bin
#neigh_modify delay 5
# correction terms for truncated tail of LJ
pair_modify tail yes
#initializing velocity
#velocity all create $t 87640
#tiemstep
timestep 2.0
#thermo_style multi
thermo 100
thermo_style custom step temp ke pe pxx pyy pzz lx ly lz
#fix 2 all npt iso 1.0 1.0 500 temp $t $t 100
fix 1 all nvt temp $t $t 100 tchain 1
dump 1 all custom 1 dump.lammpstrj id type x y z
restart 5000 nacl.restart
run 100000
