Lammps version: LAMMPS 64-bit 3Nov2022 with Python
Hello. I tried to run a 10000SPCEwater-90Na±90Cl- system with lammps(system from Material studio), but Lammps got stuck after minimization. Could not find out the reason, need help. THANK YOU!
btw, this problem did not occur when I try another system(10000SPCEwater-18Na±18Cl-)
-in file:
units real
atom_style full
pair_style lj/cut/coul/long 10
kspace_style ewald 1e-6
bond_style harmonic
angle_style harmonic
variable Ttarget equal 773.15
variable Ptarget equal 1000
variable Nrun equal 10000
variable Nrun2 equal 50000
variable freq equal ${Nrun2}/100
read_data data/solution10000_90_0.55.dat
mass 1 15.9994
mass 2 1.00794
# SPCE water model
set type 1 charge -0.8476
set type 2 charge +0.4238
# from john1998
pair_coeff 1 1 0.1554 3.166
pair_coeff 1 2 0 0
pair_coeff 1 3 0.1421 2.758
pair_coeff 1 4 0.1247 3.783
pair_coeff 2 2 0 0
pair_coeff 2 3 0 0
pair_coeff 2 4 0 0
pair_coeff 3 3 0.1300 2.350
pair_coeff 3 4 0.1140 3.375
pair_coeff 4 4 0.1000 4.400
# O-H from ClayFF2004
bond_coeff 1 554.1349 1
# H-O-H from ClayFF2004
angle_coeff 1 45.7696 109.47
thermo 1
# system minimize
group w type 1 2
fix 0 w setforce 0 0 0
velocity w set 0 0 0
minimize 1.0e-4 1.0e-6 100 1000
unfix 0
# system relaxation
velocity all create ${Ttarget} 999
fix 0 all shake 1.0e-4 200 0 b 1 a 1
fix 1 all npt temp ${Ttarget} ${Ttarget} 100 iso ${Ptarget} ${Ptarget} 1000
thermo_style custom step time temp press density vol etotal ke pe
run ${Nrun}
# data collection
reset_timestep 0
dump 1 all custom ${freq} output/dump.${filename}.dat id type q xs ys zs
compute rdf all rdf 1000 3 1 4 1 3 4 1 1
fix saverdf all ave/time 1 ${Nrun2} ${Nrun2} c_rdf[*] file output/rdf.${filename}.dat mode vector
run ${Nrun2}
- and the last bit of cmd and log file:
