ffield.Al&RDX&HMX.ReaxFF (15.5 KB)
Dear LAMMPS users:
I am running a reaxFF MD simulation and I expect to analyze the products by fix reaxff/species command. The timestep is 0.1 fs.
RUN.in (4.3 KB)
If I remove the fix reaxff/species command, the simulation can run without any problem. However, once I active the fix reaxff/species command, the simulation will stuck at a certain step without any error or warning. I also try to perform the same input file with different number of processors, but the only difference is the simulation will get stuck in different steps.
I know fix reaxff/species command will change the neighbor settings, so I choose a conservative setting as: 1 10 5000 for Nevery Nrepeat Nfreq respectively.
Could anyone explain this problem? Why fix reaxff/species command will affect the running of simulation?
HTPBsys.data (1.7 MB)
PS: I run simulations on both LAMMPS/3Aug2022 and LAMMPS/23Jun2022_update2 version, but the problem is the same.
