Hi all,
I intend to create a 3D HCP Ti crystal structure by utilizing lammps
lattice command. For that I'm using this pieces of lines as lammps input,
Hi
For hcp command the c/a is fixed. The parameter you should provide is a.
For a different c/a, you should define all the basis set. See lattice command in the manual. In the discussion forum this is also described.
Best
Pascal
Hi all,
Equilibrated Lattice parameters depends on the potential function used. There is no guarantee that they would have a perfect c/a ratio should the potential function be not optimised for it.
Best wishes, Saurav
