Hi,all
I write a new pair_style “pair_style sh/cut” and I make it successfully.
When I run a simulation using it in it, "Segmentation fault " appears.
So, I debug it with “gdb” and the informations given are:
gdb) where
#0 0x00000000005bc025 in LAMMPS_NS::PairSHCut::compute (this=0x9a4e200, eflag=1, vflag=)at pair_sh_cut.cpp:153
#1 0x0000000000590f88 in LAMMPS_NS::PairHybrid::compute (this=0x9a4dd70, eflag=1, vflag=) at pair_hybrid.cpp:93
#2 0x0000000000608082 in LAMMPS_NS::Verlet::setup (this=0x99c1a20) at verlet.cpp:111
#3 0x00000000005eaa69 in LAMMPS_NS::Run::command (this=0x7fff56658660, narg=1, arg=0x9a4f860) at run.cpp:173
#4 0x0000000000516cb6 in LAMMPS_NS::Input::execute_command (this=0x99af220) at run.h:16
#5 0x00000000005176d8 in LAMMPS_NS::Input::file (this=0x99af220) at input.cpp:195
#6 0x000000000051f797 in main (argc=1, argv=0x7fff56659118) at main.cpp:29
Is there anyone who can give me some help ? Any help will be appreciated!
Best wishes
zhang
In addition, my system is redhat and the compiler is mpicxx.
2011/2/28 xiangxiong zhang <[email protected]…24…>
Hi,all
I write a new pair\_style "pair\_style sh/cut" and I make it
successfully.
appears.
So, I debug it with "gdb" and the informations given are:
gdb) where
eflag=1, vflag=<value optimized out>)at pair_sh_cut.cpp:153
eflag=1, vflag=<value optimized out>) at pair_hybrid.cpp:93
verlet.cpp:111
at run.h:16
input.cpp:195
appreciated!
well, gdb tells you that it crashes in your code and on line 153 at that.
since i am not a psychic, i don't know what you have written there,
so it is up to you to debug your own errors.
cheers,
