Hi all:
I got a deformed box after npt run with style “xyz”. At the beginning, the length abc for the box is “27.350174 27.743213 . After 360000 run, they change to “40.909782 27.702092 .According to the introduction in the Manuel for “fix npt”, the ratio of the box length should keep as a constant. For example, begin with “ 10 10 and end with “ 1 1 . Am I right?
My calculations are:
Command. “fix npt GB npt/asphere 2.99 2.99 0.1 xyz 4.4 4.4 20 dilate partial”
Model. The model is composed with a big box of gay-berne particles and a frozen LJ cylinder inside. The beginning structure is an equilibration model under temperature 1.6 which was obtained by “fix npt aniso”. It is stranger that the round cylinder change to an ellipse based on the deformed box even if I used “dilate partial”.
Some parts of the log file.
Resetting global state of Fix npt Style npt/asphere from restart file info
run 360000
Memory usage per processor = 7.74627 Mbytes
Step Temp a_temp Press Volume PotEng KinEng Lx Ly Lz Pxx Pyy Pzz Pxy Pxz Pyz
0 1.1152402 1.6140644 4.2056315 55429.878 -9.220792 1.6727647 27.350174 27.743213 73.051153 4.0576136 4.1164169 4.442864 0.091552759 -0.033139145 -0.0046028051
30 1.2946492 1.867878 4.6535962 55428.957 -9.0815238 1.9418628 27.350665 27.742776 73.049779 4.4933248 4.5434126 4.9240512 0.089522068 -0.037508084 -0.0081701676
157260 2.6269575 3.8154234 3.9850509 79760.434 -2.3971322 3.940211 34.920464 29.689816 76.930756 4.1430258 3.9904494 3.8216776 -0.04386914 -0.036192763 0.06978516
157290 2.6210953 3.8047651 4.0600687 79768.83 -2.3699715 3.9314182 34.922509 29.690554 76.932435 4.1309455 4.118975 3.9302855 -0.019013488 -0.054406976 -0.021494459
359940 2.6564822 3.8150489 4.0817145 79672.389 -2.3678149 3.9844955 40.90657 27.701783 70.308374 4.0459204 4.2123908 3.9868323 0.071709891 -0.0021466466 0.0019907827
359970 2.6299152 3.8167443 3.9938929 79676.102 -2.3939057 3.9446473 40.908165 27.701931 70.308534 4.0254625 4.0933386 3.8628774 -0.18279552 0.014836804 -0.0062076119
360000 2.6175971 3.7787918 4.0704951 79679.935 -2.3715327 3.9261712 40.909782 27.702092 70.308728 4.0878285 4.1204091 4.0032475 -0.046842745 -0.079709734 0.044526091
Loop time of 234162 on 4 procs for 360000 steps with 17492 atoms
