Dear all
I’m trying to calculate a correlation using the "fix ave/correlate/long” command.
The issue that I’m having is the precision of the output is too low (only 6digits) when the “file” keyword used.
After researching, I found that I can access the data internally using python, more specifically, with “extract_fix”.
However, I can’t get this command work with the "fix ave/correlate/long” command.
I checked it with other fixes such as "fix ave/correlate” command, and it works just fine.
I think the issue is related to the logarithmic nature of the "fix ave/correlate/long” command.
I’d appreciate if you can point me out what mistake I’m making.
Using python is not a must.
If there’s a way to access the data with 16 digit precisions, please let me know.
Below is more detailed information of what I’m trying to do.
Miru
