In “force.h”,
double boltz; // Boltzmann constant (eng/degree-K)
I think the line should be changed to be:
double boltz; // Boltzmann constant (eng/temp)
because the unit of boltz is energy unit/temperature unit
Xiaoliang
degree-K is temperature, i.e. the temperature in degrees Kelvin
I mean if the unit of boltz should be in some relation with units user defined, i.e., units lj, units metal ,etc. not just eng/degree-K
Maybe degree-K should be the temperature unit as in units command?
Am I wrong?
Xiaoliang
— 10年4月29日,周四, Steve Plimpton [email protected] 写道:
I dont see anything wrong, myself. The value of boltz is correctly defined in all units in Energy/K.
for metal, it is in eV/K
for si it is in J/K
for cts it is in ergs/K
for reduced, it is 1
for real, it is kCal/mol/K
Xiaoliang,
Technically, you are right, because the lj unit of temperature is arbitrary, and so is not necessarily Kelvin. Also, there may come a time when LAMMPS supports a temperature unit of Fahrenheit (unlikely) or maybe kilokelvin (why not!). That said, the existing description should be pretty unambiguous to most people smart enough to read the source code.
Aidan
