hi,
I am trying to simulate tensile strain for nanowire
using NVT ensemble. I am so confused the compute temp
command. As far as I understand, if I use fix nvt
command, I should use compute fix-ID_temp command. My
question is that If I use these commands, should I
compute temperature firstly in 3D dimension, then 2D
dimension? and how can I determine compute fix-ID_temp
command to use two different dimensions?
Thanks.
Dilek Cakiroglu
Mechanical and Aerospace Engineering
Oklahoma State University
