Hi there,
I am using command fix thermal/conductivity to compute the thermal conducitivity of carbon nanotube. However, I was unable to get the correct temperature profile after arriving at the steady state. Can anybody tell me what part I used was wrong? My guesssing is the problem occurs at fix ave/spatial part to output the temp profile. or can anybody give me your already checked code (as simple as it can) to let me learn? Thanks for your help.
atom_style atomic
pair_style tersoff
read_data data.dat
pair_coeff * * SiC.tersoff C
mass 1 12
velocity all create 300 873586443 dist gaussian
fix 1 all nvt 300.0 300.0 0.5 drag 0.4
#output of varaibles
thermo_style custom step temp pe ke etotal pxx pyy pzz
thermo 1000
timestep 0.001
run 10000
unfix 1
fix 1 all nve
fix 2 all thermal/conductivity 100 z 40
compute ke all ke/atom
variable temp atom c_ke[]/1.5
fix 3 all ave/spatial 10000 1 100000 z lower 0.25 v_temp &
file tmp.profile units reduced
dump 1 all custom 100000 dump.* tag x y z
run 1000000
AC
