Hi all,
I'm trying to anneal a grain boundary in silicon. My annealing
"protocol" is as follows: using a constant (zero) pressure ensemble
that allows the x, y, and z direction allow to change independently, I
equilibrate the system at T = 300 K, 600 K, 900 K, and 1200 K for
50,000 md steps each. I then decrease the temperature continuously
from 1200 to 300 K over 1 million MD steps
For step 1, I use the following npt fix:
fix 1 all npt temp 300.0 300.0 .1 aniso 0.0 0.0 1000.0
and it returns this error:
ERROR: Illegal fix npt command
What am I doing wrong in my fix?
Zack Cordero
1st half of my input script:
#Annealing grain boundaries in Silicon
#initialization
echo screen
newton on
log log.si_anneal
#create atoms
atom_style atomic
read_data position1.xyz
group all type 1
pair_style tersoff
pair_coeff * * Si.tersoff Si
neighbor 2.0 bin
neigh_modify every 1
dump 1 all xyz 100 position.xyz
thermo 100
velocity all create 400 429349 dist gaussian
fix 1 all npt temp 300.0 300.0 0.1 aniso 0.0 0.0 1000.0
timestep .01
run 50000
