Dear,
–>> velocity, V_upper
------------------------------------ wall
particles
------------------------------------wall
<<–velocity V_lower
When I do NEMD simulation, there are two walls in xy plane which is periodic boundary, and I need a bouce-back boundary near walls.
How can I do? any suggestions?
Thanks in advance.
LAMMPS has a fix wall/reflect command, but
I don't think of it typically being used with NEMD
models. See the NEMD howto sub-section in
doc/Section_howto.html for details.
Sir,
Thanks for your suggestion, I have read the howto sub-section. But I think the fix deform command is not suitable for my simulation.
I only need create a velocity profile and not change simulation box . I want to use bounceback reflection to reproduce a no-slip boundary condition , whereby if
(V_particle_old *n_wall) < 0
for a particle in the wall region, then its velocity is reassigned as
V_particle_new = 2 * V_wall - V_particle_old
There maybe other methods to deal with it, BUT I have no ideas with lammps. It’s appreciated if some kind people give some advice. Thanks a million.
-------->> V_upper_wall
particles
<<------- V_lower_wall
2008/4/14, Steve Plimpton <sjplimp@…24…>:
You'd have to write your own fix to implement this
BC.
