Is there a reason that the long range electrostatics are not included when using the dump epair command? If I use the command
pair_style lj/charmm/coul/long 8.0 10.0
kspace_style pppm 1e-04
dump 1 all custom 10 test.lammpstrj tag epair
and add up all of the energies, the total is only equal to e_coul + e_vdwl (e_long is not included). If I do
pair_style lj/cut/coul/cut 10.0
kspace_style none
then I get the correct result. Was this by design?
Regards,
Tamara
