Dear developers:
I have a problem.
I write a fix that needs neighborlist.
I find out there are some bugs when I recall this fix.
To be specific : Is there any step skipped when a certain type of fix is recalled?
crash with multiple cores:
fix 1 sph myfix sol wall ${rc} …
run 100
unfix 1
run 100
Normal runs:
do something…
run 100
run 100
I must miss something.
Welcome for any hint:
Here’s the structure of my fix (only show the part with memory allocations and the parts need list):
FixNVESPHDIFF::FixNVESPHDIFF(LAMMPS *lmp, int narg, char **arg) :
Fix(lmp, narg, arg)
//my computations need several temporary arrays, but they do not neet to live to the next timestep:
dr=NULL;
dkg=NULL;
rho_temp=NULL;
kappa=NULL; (above are per atom arrays)
weight1 = weight2 = NULL;
//my computations need several steps:
comm_forward = 8;
comm_reverse = 12;
FixNVESPHDIFF::~FixNVESPHDIFF()
memory->destroy(rho_temp);
memory->destroy(dr);
memory->destroy(dkg);
memory->destroy(kappa);
memory->destroy(weight1);
memory->destroy(weight2);
int FixNVESPHDIFF::setmask()
int mask = 0;
mask |= INITIAL_INTEGRATE;
mask |= FINAL_INTEGRATE;
mask |= INITIAL_INTEGRATE_RESPA;
mask |= FINAL_INTEGRATE_RESPA;
return mask;
void FixNVESPHDIFF::init()
int irequest = neighbor->request(this,instance_me);
neighbor->requests[irequest]->pair = 0;
neighbor->requests[irequest]->fix = 1;
neighbor->requests[irequest]->full = 0;
neighbor->requests[irequest]->half = 1;
setup array weight1 , weight2 (these are not per-atom array)
void FixNVESPHDIFF::init_list(int /id/, NeighList *ptr)
list = ptr;
void FixNVESPHDIFF::initial_integrate(int vflag)
if (atom->nmax > nmax) {
nmax = atom->nmax;
memory->create(dr,nmax,3,“fix/nve/sph/diff:dr”);
memory->create(dkg,nmax,3,“fix/nve/sph/diff:dkg”);
memory->create(rho_temp,nmax,“fix/nve/sph/diff:rho_temp”);
memory->create(kappa,nmax,3,3,“fix/nve/sph/diff:kappa”);
update x, v
comm->forward_comm_fix(this,comm_forward);
inum = list->inum;
ilist = list->ilist;
numneigh = list->numneigh;
firstneigh = list->firstneigh;
Loop over pair to get dr (in order to update x and v)
void FixNVESPHDIFF::final_integrate()
do not need list shouldn’t be critical
int FixNVESPHDIFF::pack_reverse_comm(int n, int first, double *buf)
void FixNVESPHDIFF::unpack_reverse_comm(int n, int *list, double *buf)
int FixNVESPHDIFF::pack_forward_comm(int n, int *list, double *buf, int pbc_flag, int *pbc)
void FixNVESPHDIFF::unpack_forward_comm(int n, int first, double *buf)
Thanks for any suggestion.
