Hello everyone,
I’m trying to build lammps with the MEAM package. I followed the instructions on the LAMMPS documentation, and first I built the library libmeam.a in the lammps/lib/meam directory (using ifort). I then modified my Makefile in the LAMMPS src directory to include a link to the library:
LINKFLAGS = -O -L/home/jasanc2/lammps-24Sept07/lib/meam
USRLIB = -lmeam -lstdc++
however, when I compiled the code I get multiple errors like this one:
/home/jasanc2/lammps-24Sept07/lib/meam/libmeam.a(meam_setup_done.o)(.text+0x7c2): In function compute_pair_meam_': undefined reference to
for_check_mult_overflow64’
/home/jasanc2/lammps-24Sept07/lib/meam/libmeam.a(meam_setup_done.o)(.text+0x130b): In function compute_pair_meam_':undefined reference to
for_write_seq_lis’
There’s a section in the documentation that says: “Note that linking a Fortran library to a C++ code can be problematic (e.g. Fortran routine names can’t be found due to non-standard underscore rules) and typically requires additional C++ or F90 libraries be included in the link. You may need to read documentation for your compiler about how to do this correctly.”
I think this might be the source of the error I’m getting and I was wondering if anyone had come across this and could give me any suggestions.
thanks
Jaime Sanchez
Hello everyone,
I'm trying to build lammps with the MEAM package. I followed the
In function `compute_pair_meam_': undefined reference to
`for_check_mult_overflow64'
In function `compute_pair_meam_':undefined reference to `for_write_seq_lis'
jaime,
you are missing to provide the library with the functions needed
by the intel fortran runtime (-lifcore). see my mail to this
list of about 10 days ago in the source forge mailing list archives.
There's a section in the documentation that says: "Note that linking a
can't be found due to non-standard underscore rules) and typically requires
read documentation for your compiler about how to do this correctly."
I think this might be the source of the error I'm getting and I was
yes, you are right. the suggestion in the manual to read the
fortran compiler documentation is actually a pretty good one
already. searching through the mailing list archive or using
google, should have told you at least, that you are not the
first person with this problem. ;-))
cheers,
Hi Axel,
thank you for the suggestions. I was able to make lammps with the MEAM package and run the examples given in lammps.
Jaime
