I'm having a lot of trouble building LAMMPS with MEAM and MPI support on a x86 Red-Hat linux cluster. I have tried both Intel's icc/mpicc compiler/linker (with Intel's MPI and MPICH) and GNU's gcc/mpicc compiler/linker with MPICH to compile. However, I can't get MEAM to link with LAMMPS.
Additionally, I noticed the curious behavior that MEAM compiles without a hitch using ifort, but will not compile using g95 (latest stable release)
I'm not worrying about FFTW for now although it causes another set of problems. I receive a huge number of errors if using Intel's MPI 2.0, but I can reduce the number of errors by using the same makefile, but with Intel's MPICH. The makefile and error log from the Intel compiler are attached.
Makefile:
#Compiler options
CC = icc
CCFLAGS = -I${HOME}/lammps/lib/meam -I${HOME}/fftw/include -I/opt/mpich/intel/include -O -DFFT_NONE -DGZIP -DMPICH_IGNORE_CXX_SEEK
DEPFLAGS = -M
#Linker options
LINK = mpicc
LINKFLAGS = -O -L${HOME}/lammps/lib/meam -L/opt/mpich/intel/lib -L/opt/intel/fce/9.0/lib -L${HOME}/lammps/src/MEAM/
USRLIB = -lmpich -lmeam -lifcore -lifcoremt -lcxaguard
SYSLIB = -lpthread -lstdc++
ARCHIVE = ar
ARFLAGS = -rc
SIZE =
The errors are:
IPO link: can not find "-lstdc++_shared"
icc: error: problem during multi-file optimization compilation (code 1)
make[1]: *** [../lmp_mpich] Error 1
make[1]: Leaving directory `/export/home/cjo123/lammps/src/Obj_mpich'
make: *** [mpich] Error 2
FYI:
When using Intel's MPI 2.0 in lieu of MPICH I receive the error:
/usr/bin/ld: skipping incompatible /export/home/cjo123/lammps/lib/meam/libmeam.a when searching for -lmeam
/usr/bin/ld: cannot find -lmeam
collect2: ld returned 1 exit status
make[1]: *** [../lmp_icc] Error 1
make[1]: Leaving directory `/export/home/cjo123/lammps/src/Obj_icc'
make: *** [icc] Error 2
I would greatly appreciate any help with this problem.
Christopher J. O'Brien
Graduate Student
The Pennsylvania State University
Department of Engineering Science and Mechanics
