I am now running a simulation with MEAM potential. During the calculation i need the centro-symmetry parameter to check the location where dislocation occurs. Normally, the centro-symmetry parameter for disloaction is 2 and above 20 for surface atoms. But the centro-symmetry parameter i get from dump file are abnormal. Even for the surface atoms, the centro-symmetry parameters are too small.
In order to check my system, I used EAM for the same system again and this time the centro-symmetry parameter were all fine.
Could you please kindly tell me whether the centro-symmetry parameter is related to the potential i use? I think it shoule only related to the geometric condition of the system?
By the way, the version of lammps i use is 22Jun-2007
Thanks a lot!
Regards
Yi
