Hi lammps users,
Is there any way to quit “run” when satisfied some condition. For example, I would like quit “run” when satisfied the condition for variable: “step > 2000” and “bondLength > 8”, So I guess we can implement something like :
if “({step} > 2000) && ({bondLength}> 8)” then “quit”
run 10000
Unfortunately , the above “if” command is only executed once at first time, and do not run again.
The other method to quit run could be using “fix halt” command like:
fix 1 all halt 100 v_step >2000
run 10000
As you can see, the “fix halt” command only allows one condition, however, I have two variable conditions. So is there anyway to quit “run” when both two conditions are satisfied?
Thank you in advance.
Jiang Xiao
Hi lammps users,
run 10000
no.
that is how LAMMPS inputs work. each line is always acted upon immediately.
anything else only makes sense to a human, not a computer.
run 10000
you can use conditions inside an equal style variable.
variable stop equal “(v_step > 2000) && (v_bondLength > 8)”
and then
fix 1 all halt 100 v_stop>0
