Dear LAMMPS users,
I am performing a tensile simulation using the "fix deform" command with the "erate" keyword, in order to strain my system at a fixed "engineering strain rate". The "fix deform" command uses an initial value L0, the initial box length, in order to calculate the change in the current box length L.
The documentation says that this L0 is the value from a create_box, read data, or read_restart command. My question is: can I specify another value as L0? In my case, I set up my system and then let it relax for a while. During the relaxation the box length usually changes a bit, and I would like to use this "new" L0 as the L0 in the "fix deform" command. Is this possible, and if so, how?
Thanks for your answers and suggestions.
Sincerely,
Christer H. Ersland.
