Dear LAMMPS users,
I wish to simulate a protein in a sugar solution, modeled by CHARMM all22_prot and all36_carb respectively. I have succeeded in building the system for CHARMM (with appropriate pdb and psf files). When I simulate with NAMD2, I list both prot and carb parameter files in the input script. But when I attempt to convert the pdb and psf files to a LAMMPS data file, the ch2lmp tool supports only one set of CHARMM parameter and topology files. If I attempt to use ch2lmp with only one of the pairs of par/top files, an unusable LAMMPS data file results.
Essentially, this is a simple problem. I can simulate both protein and sugar with lammps. Is there an easy way to combine the two sets of forcefield files into one set so I can use ch2lmp on the combined psf/pdb? Alternatively, is there a simple way to combine separate data files for the protein and sugar?
Harold
