In my simulations, I need to change type/charge of an atom during the run time. Is there a simple way to do that?
I used the fortran version of lammps before and I usually do this kind of modifications in the diagnostic.f routine. Is there a similar user defined routine in the C++ version of lammps?
The set command will let you change such things between runs.
It could also be used with the run every command to do something
periodicically during a run. If you want something more specific,
you could write a fix that will get called every timestep which
will do whatever you want. It's like the diagnostic option in
the old LAMMPS you mentioned.
