Dear All,
I implemented a new force field pretty much similar to the existing SW
with electrostatic considerations. I would like Lammps to read the
potentials from file with a different extension than ".sw"
I search the code to check where the extension ".sw" is specified
without success.
Any idea?
Thanks in advance foe any help.
Best wishes,
Adama
Dear All,
without success.
Any idea?
how about, lammps doesn't check the extension at all?
have a look at pair_sw.cpp.
the coeff() method takes the third argument and calls the read_file()
method. no check on extensions at all. the code will read whatever
file name you give it (after all, it is written with unix in mind, where
extensions are merely a convention to be able to tell files apart and
do not change the functionality as such).
cheers,
Axel,
Thank you very much for your answer. This is exactly what I though but I
was not very sure.
Best wishes,
Adama
