Dear LAMMPS users,
When I attempt to read a restart file from a simulation that used kspace_style ewald (or pppm), but change the pair_style to one which does not use kspace (setting kspace_style to none), I receive the following error: “ERROR: Pair style is incompatible with KSpace style.” The input script is show below, where meoh.rst used lj/charmm/coul/long pair_style. In my application, I am using a custom pair_style I developed to post-process which doesn’t require kspace, but the pair_style ‘lj/charm/coul/charmm’ experiences the same problem.
I attempted to get around this problem by converting the restart file to a data file, however, the data file loses too much precision to be an accurate representation of the simulated ensemble (for example, energy and pressure are too different). So I need a way to use the binary coordinates.
One solution I considered is to convert my custom pair_style to a compute. It was much simpler to edit a pair_style when developing the post-processing calculation, because there wasn’t a compute that was similar to what I wanted to calculate. It seems to me that it would be easier to suppress the kspace style when reading a restart, than to convert the custom pair_style to a compute.
Thank you,
Harold Hatch
units real
atom_style full
bond_style harmonic
angle_style charmm
dihedral_style charmm
pair_style lj/charmm/coul/charmm 8.0 9.0
pair_modify mix arithmetic
kspace_style none
read_restart meoh.rst
special_bonds charmm
