Estimated LAMMPS Users
I am simulating a system (water-protein-metal oxide) and I want to use 3 types of potential pairs, in the input script I wrote the following:
pair_style hybrid buck/coul/long 13.0 lj/cut/coul/long 13.0 lj/charmm/coul/long 8.0 13.0 lj/cut 13.0
pair_modify mix arithmetic
kspace_style pppm 1.0e-6
##======= Potential (Matsui and Akaogi)-Metal Oxide========================================
pair_coeff 34 34 buck/coul/long 717653.9571 0.154 120.9967 #
pair_coeff 33 34 buck/coul/long 391052.7442 0.194 290.3920 #
pair_coeff 33 33 buck/coul/long 271718.8311 0.234 696.9407 #
##=======Lennard Jones Potential (coulombic long-range)-Water ====================================
pair_coeff 36 36 lj/cut/coul/long 0.15535 3.166 #
pair_coeff 35 35 lj/cut/coul/long 0.04600 0.400 #
pair_coeff 35 36 lj/cut/coul/long 0.0000 0.0000 #
##=======Lennard Jones Potential (Metal-water) ======================================================
pair_coeff 34 36 lj/cut 7.72528 2.3431 #
pair_coeff 33 36 lj/cut 0.22784 3.1306 #
pair_coeff 34 35 lj/cut 0.00000 0.000 #
pair_coeff 33 35 lj/cut 0.00000 0.000 #
Is it possible to use the pair_modify mix arithmetic command only for the protein atom group? Since for other atoms I want to apply coefficients calculated manually (as indicated above). I put the coefficients for the lj/charmm/coul/long in the data.file for LAMMPS to mix automatically, however I get the following error: Must define pair_style before Pair Coeffs (…/read_data.cpp:585).
Pair Coeffs # lj/charmm/coul/long
1 0.046 0.400013524445 0.046 0.400013524445 # H
2 0.046 0.400013524445 0.046 0.400013524445 # HC
3 0.03 2.42003727796 0.03 2.42003727796 # HP
4 0.022 2.35197261589 0.022 2.35197261589 # HB1
5 0.028 2.38760856462 0.028 2.38760856462 # HB2
6 0.045 2.38760856462 0.045 2.38760856462 # HA1
7 0.034 2.38760856462 0.034 2.38760856462 # HA2
8 0.024 2.38760856462 0.024 2.38760856462 # HA3
9 0.11 3.56359487256 0.11 3.56359487256 # C
10 0.07 3.55005321205 0.07 3.55005321205 # CA
11 0.032 3.56359487256 0.01 3.38541512893 # CT1
12 0.056 3.58141284692 0.01 3.38541512893 # CT2
13 0.056 3.58141284692 0.01 3.38541512893 # CT2A
14 0.078 3.63486677001 0.01 3.38541512893 # CT3
15 0.099 3.31414323148 0.099 3.31414323148 # CPT
16 0.073 3.5457768982 0.073 3.5457768982 # CY
17 0.02 4.05358916754 0.01 3.38541512893 # CP1
18 0.055 3.87540942391 0.01 3.38541512893 # CP2
19 0.055 3.87540942391 0.01 3.38541512893 # CP3
20 0.07 3.56359487256 0.07 3.56359487256 # CC
21 0.073 3.5457768982 0.073 3.5457768982 # CAI
22 0.2 3.29632525712 0.0001 3.29632525712 # N
23 0.2 3.29632525712 0.2 2.76178602624 # NH1
24 0.2 3.29632525712 0.2 3.29632525712 # NH2
25 0.2 3.29632525712 0.2 3.29632525712 # NH3
26 0.2 3.29632525712 0.2 3.29632525712 # NC2
27 0.2 3.29632525712 0.2 3.29632525712 # NY
28 0.2 3.29632525712 0.2 3.29632525712 # NP
29 0.12 3.02905564168 0.12 2.49451641079 # O
30 0.12 3.02905564168 0.12 3.02905564168 # OC
31 0.1521 3.15378146222 0.1521 3.15378146222 # OH1
32 0.45 3.56359487256 0.45 3.56359487256 # S
Is there any way that LAMMPS can help me by calculating the mixture of the potential coefficients lj/charmm/coul/long but at the same time I can place coefficients manually for other atoms? I understand that you can define the coefficients either in the inputscript or in the data.file, but I don’t know which would be a proper trick.
Sincerely
Eduardo
