Hi
I have managed to install lammps and some of the utilities on my mac. This was more a matter of luck than skill because I really don't know what I am doing when it comes to compilations. However, I am having problems with xmovie. I have x11 installed but I don't think this is the problem.
Any help in translating and fixing the following will be greatly appreciated:
thanks much
matthew
n1-19-194:xmovie matthew$ make
gcc -c -O2 -finline-functions -g -DMISSINGDEFS -D_POSIX_SOURCE -DUSEPRIVATE -DINCL_FLOAT -Wimplicit -Wunused -Wmissing-prototypes xmovie.c
gcc -c -O2 -finline-functions -g -DMISSINGDEFS -D_POSIX_SOURCE -DUSEPRIVATE -DINCL_FLOAT -Wimplicit -Wunused -Wmissing-prototypes control.c
gcc -c -O2 -finline-functions -g -DMISSINGDEFS -D_POSIX_SOURCE -DUSEPRIVATE -DINCL_FLOAT -Wimplicit -Wunused -Wmissing-prototypes scene.c
scene.c: In function ‘MotionUpdate’:
scene.c:155: warning: passing argument 4 of ‘XpmWriteFileFromPixmap’ makes integer from pointer without a cast
scene.c: In function ‘SceneSave’:
scene.c:188: warning: passing argument 4 of ‘XpmWriteFileFromPixmap’ makes integer from pointer without a cast
gcc -c -O2 -finline-functions -g -DMISSINGDEFS -D_POSIX_SOURCE -DUSEPRIVATE -DINCL_FLOAT -Wimplicit -Wunused -Wmissing-prototypes read.c
read.c: In function ‘SortData’:
read.c:981: warning: passing argument 1 of ‘hpsort’ from incompatible pointer type
read.c:981: warning: passing argument 4 of ‘hpsort’ from incompatible pointer type
gcc -c -O2 -finline-functions -g -DMISSINGDEFS -D_POSIX_SOURCE -DUSEPRIVATE -DINCL_FLOAT -Wimplicit -Wunused -Wmissing-prototypes hpsort.c
hpsort.c:11: warning: no previous prototype for ‘hpsort’
hpsort.c: In function ‘hpsort’:
hpsort.c:18: warning: implicit declaration of function ‘malloc’
hpsort.c:18: warning: incompatible implicit declaration of built-in function ‘malloc’
hpsort.c:21: warning: implicit declaration of function ‘memcpy’
hpsort.c:21: warning: incompatible implicit declaration of built-in function ‘memcpy’
hpsort.c:23: warning: incompatible implicit declaration of built-in function ‘memcpy’
hpsort.c:35: warning: incompatible implicit declaration of built-in function ‘memcpy’
hpsort.c:40: warning: incompatible implicit declaration of built-in function ‘memcpy’
hpsort.c:42: warning: implicit declaration of function ‘free’
gcc -c -O2 -finline-functions -g -DMISSINGDEFS -D_POSIX_SOURCE -DUSEPRIVATE -DINCL_FLOAT -Wimplicit -Wunused -Wmissing-prototypes version.c
gcc -o xmovie -O2 -finline-functions -g version.o xmovie.o control.o scene.o read.o hpsort.o -L/usr/X11R6/lib -lX11 -lXaw -lm
Undefined symbols:
"_XtFree", referenced from:
_SceneDraw in scene.o
_SortData in read.o
_NewData in read.o
"_transientShellWidgetClass", referenced from:
_transientShellWidgetClass$non_lazy_ptr in control.o
_transientShellWidgetClass$non_lazy_ptr in scene.o
"_XtRealizeWidget", referenced from:
_main in xmovie.o
"_XtCreatePopupShell", referenced from:
_init_quit in control.o
_init_atoms in control.o
_init_bg in control.o
_init_file in control.o
_init_bonds in control.o
_CreateControl in control.o
_CreateScene in scene.o
"_overrideShellWidgetClass", referenced from:
_overrideShellWidgetClass$non_lazy_ptr in control.o
"_XtScreen", referenced from:
_NewDataSetup in scene.o
"_XtAppAddWorkProc", referenced from:
_main in xmovie.o
"_XtRealloc", referenced from:
_ReadProc in read.o
_ReadProc in read.o
"_XtVaCreateManagedWidget", referenced from:
"_XtDisplay", referenced from:
_DrawAxes in control.o
_color_apply in control.o
_bond_apply in control.o
_bg_apply in control.o
_file_apply in control.o
_SceneSave in scene.o
_SetAtomColors in scene.o
_SetBGColor in scene.o
_SetBondColors in scene.o
_MotionUpdate in scene.o
"_XtPopup", referenced from:
_do_popup in control.o
"_XtPopdown", referenced from:
_cancel_popup in control.o
"_XtCreateManagedWidget", referenced from:
"_XtAppMainLoop", referenced from:
_main in xmovie.o
"_XtVaSetValues", referenced from:
_SetTime in control.o
_NewSpeed in control.o
_NewPosition in control.o
_NewThickness in control.o
_SetReadString in control.o
"_XtMalloc", referenced from:
_main in xmovie.o
_main in xmovie.o
_main in xmovie.o
_SortData in read.o
_NewData in read.o
_NewData in read.o
_NewData in read.o
_NewData in read.o
_NewData in read.o
_CopyBond in read.o
_ReadPosition in read.o
_ReadBond in read.o
_ReadProc in read.o
"_XtAppInitialize", referenced from:
_main in xmovie.o
"_XtVaGetApplicationResources", referenced from:
_main in xmovie.o
"_XtRemoveTimeOut", referenced from:
_RemoveMotion in scene.o
"_XtAddCallback", referenced from:
"_XtConvertAndStore", referenced from:
"_XtTranslateCoords", referenced from:
"_XtWindow", referenced from:
"_XtAppAddActions", referenced from:
_main in xmovie.o
"_XtWidgetToApplicationContext", referenced from:
_SetRadio in control.o
_quit_ok in control.o
_InstallMotion in scene.o
"_XpmWriteFileFromPixmap", referenced from:
"_XtAppAddTimeOut", referenced from:
"_XtIsRealized", referenced from:
"_XtVaGetValues", referenced from:
_visible_toggle in control.o
_bvisible_toggle in control.o
_PositionUpdate in control.o
_ThicknessUpdate in control.o
_SpeedUpdate in control.o
_AxisSelect in control.o
_SceneSize in scene.o
"_XtDestroyApplicationContext", referenced from:
"_XtStrings", referenced from:
_resources in xmovie.o
_XtStrings$non_lazy_ptr in control.o
_XtStrings$non_lazy_ptr in scene.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
make: *** [xmovie] Error 1
