Does the "compute heat/flux" support charged pairwise potentials such as
Coulombics interaction?
Regards,
Ali Rajabpour
The compute heat/flux command authored by Reese, Philip, Vikas
was released today in a 6Jul09 patch.Steve
Hi Reese,
I'm also interested in code for heat flux.
I would really appreciate if you can send it to me.
German SamolyukHi Bill,
I have working, validated code for computing the heat flux and a
python script for computing the necessary autocorrelation and its
integration. This was developed by Vikas Varshney, Phillip Howell and
myself. I am cleaning it up and giving it to Steve P. in the next week
or so.
I can send you the cleaned up version and the correlation script at
the same time I send it to Steve if you would like.
Reese
WJ Evans wrote:
Hi Steve,
There are several advantages of the Green-Kubo (GK) method compared
to the
non-equilibrium method (NEMD). 1) Because GK simulations are done
with the
system in equilibrium, there is no imposed driving force and so the
system
is always in the linear-response regime. 2) The GK method can compute
the
entire heat flux tensor with one simulation. NEMD would require a
simulation
run for each component of the heat flux vector. There the GK method
lends
itself much easier to the study of anisotropic effects. 3) A key
advantage
to the GK method is that it is much less sensitive to finite model size
effects because a heat source and sink are not required. Hence the GK
method
can use much smaller models than the NEMD methods. For example, good
results
for diamond were obtained with only a 4000 atom model with a
dimension of
about 2.8 nm. The NEMD method would require a model comparable tot he
mean
free path length (174 nm).
Of course there are disadvantages of the GK method compared to the NEMD
method but I have only discussed the positive attributes of the GK
method.
A way to implement the GK in lammps would be beneficial to many
researchers.
I would be interested in obtaining a copy of any GK source code
additions to
lammps if anyone has been successful in implementing it.
Bill Evans
To: <[email protected]>
Sent: Tuesday, April 14, 2009 9:24 AM
Subject: [lammps-users] Fwd: Thermal Conductivity Calculation
usingGreen-Kubo Relations
Date: Tue, Apr 14, 2009 at 7:23 AM
Subject: Re: [lammps-users] Thermal Conductivity Calculation using
To: German Samolyuk <[email protected]...>
Cc: Mario Pinto <[email protected]...>, [email protected]...I don't think anyone has answered my question of how
is this different than the Muller-Plathe method. For
viscosity the MP method is almost always better than
the traditional NEMD way of computing it. I'm guessing
the same is true of MP for thermal conductivity versus
the GK method. MP will converge much more quickly
than GK b/c the induced temp profile in MP is stable, whereas the
induced heat flux in GK is a quantity with large fluctuations. In
viscosity it is the off-diagonal pressure component that fluctuates
widely
and MP avoids computing it at all.
I also disagree with the statement below that GK can easily
be implemented for many-body potentials. It would require
inserting new code in every such potential in LAMMPS (AIREBO,
Tersoff, MEAM, ReaxFF, etc). By contrast the MP method just
works with any potential without the need to alter the potential at all.
It also just works with long-range Coulombics.Are there other downsides to MP for thermal K that I am missing?
the coefficient of thermal conductivity for the system in thermal
quilibrium, according to Green-Kubo method, equals
k=1/(3*volume*k_B*T*T) \int^{\inf}_{0}<J(t)J(0)> dt
there <> means ensemble average.
What is good in this expression - it's calculated in thermal
equilibrium, not so good - the ensemble average should be
calculated. Usually it's done by slicing results of one long enough
calculations by overlapping in time samples separated by t_{shift}
long
enough for the samples to be independent.
So
good - thermal equilibrium, bad - long calculations to reach
convergence in <> calculations.
Usually it's good to have value of thermal conductivity calculated
by two methods.
The many-body potentials was not inserted yet, I don't think it's
something very difficult.
I think Asegun Henry did it for LAMMPS.
German
A conceptual question on this topic. I don't know the details of
Green-Kubo for thermal conductivity. But isn't it essentially the
inverse of the Muller-Plathe method encoded in fix
thermal/conductivity?
I.e. in one case you impose a temperature difference and tally the
heat flux that results. In the other case you exchange bits of heat
flux and monitor the temperature profile that results.
If the two methods are essentially equivalent, and the GK has the
various difficulties you mention, and what you've done doesn't look
like it would address many-body potentials, then why not just use
fix thermal/conductivity?
Hi all,
I was not sure if it's a good idea to all lammps users, because it
still in testing phase.
If you think it will be interesting to everybody I will do it.
I've attached slightly modified style.h file. I added compute_hf.h
to it
and compute_hf.cpp, computer_hf.h files. I've used
compute_group_group.cpp
as a prototype, as soon as it has cycle over pair in it.It should be compiled
make yes-dpd,
- it uses velocities of ghost atoms.
I've also attached input file for Ar computation with two
temperatures
(in comment).
the results could be compared with results presented in chapter 2.18
of S. Yip (ed.), Handbook of Materials Modeling, 763–771. c 2005
Springer. Printed in the Netherlands.
I've deleted first 1000 iterations and calculated averaged values
over
20000 samples with 50 steps shift.
Known problems:
1) It's working with pair potentials only,
2) I do no know how to include Coulomb interaction.I would really appreciate any comments and suggestions ...
GermanDear German,
I would be very grateful if you could share your code. Could you
please
it to me and also put it on the mailing list?Thanks!
Mario PintoI have some variant of code with calculation of j(t) - heat
flux, actually energy flux.
For the calculation of lambda in the few components systems. I
tested it on a linux cluster using 32 Xenon processors for Ar -
solid and liquid.
It looks like it's working OK. So I can share it. I will appreciate
any information of
mistakes in the code.But I do not know how to include Coulomb interactions in this code.
As I understand pair->single() returns only real space part of
coulomb interaction. How I can calculate rest of the sum which
is calculated in kspace?
German SamolyukLAMMPS doesn't store Fij anywhere, it is computed in the pair
potentials, summed to Fi and Fj and discarded. You could write
a fix that looped over the neighbor list, and called
pair->single()
on each pair, which will return Fij to use however you wish.
The single() method also computes Eij.
Dear All,
I would like to calculate the thermal conductivity of a simple
one
component LJ system using LAMMPS. The Green-Kubo relation to
calculate
thermal conductivity (lambda) is:
lambda = ( 1/(3*V*kB*T^2) ) * Integral( 0 to infinity){
<j(0)j(t)>}
dt
where
j(t) = sum (over i) {v ei} + 0.5* Sum (over i,j; i not eq j) {
(Fij
dot
vi)
rij }However, I have not been able to locate the variable, (if it
exists)
that
gives the force between a given pair of particles. This would be
required to
perform the above calculation.Please can you point me as to whether such a variable exists /
any
other way
I can get a handle to this quantity.
If not, could you please provide access to this variable in
the next
release
of LAMMPS? Similarly, a variable that gives the potential between
two
specified particles would also be helpful.Any suggestions in performing the above calculations are welcome.
Cheers!
Mario PintoPS: I have looked at the thermal/conductivity fix, but that works
only
for
particles of the same mass; However in the near future I would
like
to
carry
out computations for systems consisting of a mixture of
particles.
