Hi! I am trying to calculate interparticle distances from a configuration-dump file with header
ITEM: TIMESTEP
14000000
ITEM: NUMBER OF ATOMS
100000
ITEM: BOX BOUNDS xy xz yz pp pp pp
-2.7226138904763260e+01 2.7158265908439908e+01 -4.3446974625327561e-01
-2.6695721711161067e+01 2.6681029457996679e+01 3.6659674992992375e-01
-2.6524840642222021e+01 2.6524840642222021e+01 -1.4692253164388701e-02
Using the definitions on the doc page (https://docs.lammps.org/Howto_triclinic.html), I get
xlo_bound = -27.2261
xhi_bound = 27.1583
xy = -0.43447
ylo_bound = -26.6957
yhi_bound = 26.681
xz = 0.366597
zlo_bound = -26.5248
zhi_bound = 26.5248
yz = 0.0146923
Converting these to the cell shape parameters gives
xlo = xlo_bound - min(0, xy, xz, xy + xz) = -26.7917
xhi = xhi_bound - max(0, xy, xz, xy + xz) = 26.7917
ylo = ylo_bound - min(0,yz) = -26.681
yhi = yhi_bound - max(0,yz) = 26.681
zlo = zlo_bound = -26.5248
zhi = zhi_bound = 26.5248
Using these definitions, the cell-edge (a, b, and c) vectors are
a = {xhi - xlo, 0, 0} = {53.5833, 0, 0}
b = {xy, yhi - ylo, 0} = {-0.43447, 53.3621, 0}
c = {xz, yz, zhi - zlo} = {0.366597, -0.0146923, 53.0497}
Then the h-matrix (the shape matrix whose column vectors are a, b, c) is
53.5833 -0.43447 0.366597
0 53.3621 -0.0146923
0 0 53.0497
and its inverse h_inv is
0.0186625 0.000151949 -0.000128924
0. 0.0187399 5.19007*10^-6
0 0 0.0188503
Here’s where I ran into trouble. I would expect the scaled coordinates of the cell corners {xlo, ylo, zlo} and {xhi, yhi, zhi} to be respectively
hinv {xlo, ylo, zlo} = {-.5, -.5, -.5}
and
hinv {xhi, yhi, zhi} = {.5, .5, .5}.
However, for the above hinv, they are
hinv {xlo, ylo, zlo} = {-.500634, -.500138, -.5}
and
hinv {xhi, yhi, zhi} = {.500634, .500138, .5}.
Thus the scaled cell isn’t a unit cube, so I can’t calculate interparticle distances using the usual textbook method of multiplying differences in unit-cube-scaled coordinates by h
Any idea what’s going on here? I’ve checked the math several times so I assume I’ve misunderstood something, but can’t figure out what that might be…
Thanks in advance,
Rob
