Dear lammps users
Is it possible to rotate rigid spheres with constant velocity (torque)? The problem is that I need to measure the (orientational) averaged interaction forces between 2 rough nanospheres at fixed distances in vacuum. Using fix rigid implies an NVE ensemble, i.e. in order to keep the total energy fixed, near a potential energy minimum the spheres rotate fast while close to the maxima they rotate slow which has no physical meaning. What can I do to receive a constant torque while measuring the binding energies?
Thank you for your help.
regards
Sabine
infile:
velocity all create 300 12348765
velocity all zero linear
neighbor 5.0 bin
neigh_modify delay 2
group sphere1 id <> 1 2808
group sphere2 id <> 2809 5616
velocity sphere2 zero linear
velocity sphere1 zero linear
fix 1 all rigid group 2 sphere1 sphere2 force * off off off
compute 1 sphere1 group/group sphere2
thermo 100
thermo_style custom step etotal ke c_1 c_1[1] c_1[2] c_1[3]
timestep 3
run 100000
Constant velocity and torque are not the same thing. I assume
you mean omega (rotational velocity) or angular momentum.
If you turn off torque with the fix rigid option, then the rigid
bodies will rotate with constant angular momentum. Is
that what you want?
From the fix rigid doc page:
By default, each rigid body is acted on by other atoms which induce an
external force and torque on its center of mass, causing it to
translate and rotate. Components of the external center-of-mass force
and torque can be turned off by the force and torque keywords. This
may be useful if you wish a body to rotate but not translate, or vice
versa, or if you wish it to rotate or translate continuously
unaffected by interactions with other particles
Dear Steve,
Thank you for the correction I confused the term torque with angular momentum, sorry. I have redone the simulations now fixing the rotational energies, but there are many things in the results I cannot understand.
I use compute group/group to calculate the potential energies and pair forces between the two particles. I would expect that doing it for several constrained particle positions, the integral over the forces along their connecting axis should lead to the same free energy as given by the measured potential energies, but this is by far not the case.
I think my calculations make no sense insofar as the NVE ensemble attempts to conserve the total energy, which causes problems when I fix the kinetic energies. Maybe a certain energy state of the system is then measured as it gives in average (sampled over several 100000 conf. at each constrained particle distance) completely different forces and pot. energies depending on whether I rotate the bodies with constant or changing velocities. This should not be the case if I calculated what I want: just to measure the interparticle forces and pot. energies while I rotate the particles. Is it possible at all to calculate the interaction energies for certain orientations, then to change the orientations (using run not to turn them by hand to give lammps a new data-file) and redo the calculation and so on till one has several 100000 measurement?
The system (2 rigid bodies) is for sure to small to have a stable system. Would it be a way out to increase the number of particles, to constrain two of them and use the group/group command to calculate the forces and energies.
I hope this all was not to confusing but I am gracefull for any hint you can provide.
Best regards and thank you very much.
Sabine
Steve Plimpton [email protected] 8/25/2010 4:25 PM >>>
that what you want?
Comments below.
Dear Steve,
1) I use compute group/group to calculate the potential energies and pair
If you're saying the interactions energy/force between 2 particles should
be the same for any relative orientation of the 2 particles, I don't
see why that would be the case.
2) I think my calculations make no sense insofar as the NVE ensemble
By zeroing the torque on the 2 particles (so they rotate freely) you are
certainly messing with energy conervation when the overall system is
doing NVE. It is possible to use a loop in a LAMMPS input script
and/or generate configs in different orientations using some external
program and run the set of configs thru LAMMPS. Look at the
"loop" command doc in LAMMPS or you could write a shell or Python
script to iterate over many short LAMMPS runs.
3) The system (2 rigid bodies) is for sure to small to have a stable system.
energies.
You can certainly constrain some subset of particles and you get
to define the 2 groups for group/group, so they could include
whatever atoms you want.
